Bought a new SANY SY50U !
   / Bought a new SANY SY50U ! #21
Sorry to hear but thankfully it’s all covered under warranty. If it was me while waiting for service tech I’d clean the ground strap to frame and also check the battery cut off switch .
Actually, the battery isolation switch is about the only thing I did not verify when getting to the battery to test it. I did note that the switch diagram near the switch is erroneous!
It shows vertical for off and left turn to 9 O'clock as 'on'. It's actually the opposite: 3 O'clock is 'ON', instead. I tried the key every which way I could turn it, including removing it completely from it's switch housing, (it's on a lanyard), and never bothered trying to see if when turned on it was completing the circuit through the positive cable to the rest of the machine.
So that could be a possibility I missed when doing the original diagnoses.
I was under the weather at the time so not as focused as usual. I'll look at that when I'm better and can go back out to the big hunk of inoperative metal.:(
Thanks for the suggestion!, Seven Gables- I appreciate any help to get back up and running.(y)
   / Bought a new SANY SY50U ! #23
So you did pull the bolt out of the ground strap to frame and polish that connection? , cause that would be my very first guess by the symptoms.
No on the ground strap, to date; don't know where it is and not currently able to do a seek and find mission. I did however confirm the battery isolation switch does NOT light my test light whether in the on or off positions on either post of the switch.
The battery is now showing green AND red in the 'eye'. Before it was all green...
Note the service manager did say he has seen similar symptoms where the buried in the fuse box 'sandwiched' diode has failed, and it renders no voltage at the isolation switch regardless of it being turned on or off. Sany has told him when the diode blows/burns the only solution is to replace the entire box- there is no replacing the diode, hence R&R is the fix...
I don't yet know how the wiring from the battery routes through the isolation switch and to the fuse box, etc. I will see what I can find in the service literature and try to get a better understanding of the logic applied.
   / Bought a new SANY SY50U ! #25
You’re negative cable from the battery post will go directly to the frame where it’s bolted on. This is where it needs to be unbolted and wire brushed shiny clean. If this connection is corroded you won’t have power to the battery cut off switch. I had a brand new tractor with the exact same symptoms as yours and that’s where the fault was. I’m not trying too push you while you’re not feeling well, just like to help you get it fixed when you do get to feeling better.
   / Bought a new SANY SY50U ! #26
What do you mean the battery is showing green AND red in the "eye"? Sounds like you might have a bad battery with an internal short. Charging this will do absolutely nothing as its got such a big draw internally.
When you are able, it might be worth taking the battery out of the circuit and seeing if you can jumpstart off another battery (you will need to fully disconnect the one in the machine. I have seen brand new batteries do this before.
Can I ask what part of VT you are in? Shoot me a PM if you rather.
Good news!
Spoke to service mgr., their tech will be at my place by 9AM tomorrow. He's bringing everything I mentioned earlier, including a battery, fuse box, etc.
Hopefully I'll be up and running then.
Thanks for the suggestions on what else to do.
For now I'm going to wait for the Calvary!
Got no energy to do anything at the moment. Yeah for warranty!
Will post back results.
YES!
Fixed!
It took a battery, a 300 amp fuse, and a new starter too!
The fuse was the big suprise!
YES, 300 amp!
How and why the fuse, atached to the battery positive cable, in close proximity to the positive post blew is still a mystery, and the tech didn't have a spare.
So for now the fuse is on order.
I'm running dangerous!
He had found a 2 amp parasitic draw, prior to removing the 300 amp blown fuse, for which I dont know if it remains now...
Anyway it is now running, YEAH!
more to come, I'm using my cell to send this update...
   / Bought a new SANY SY50U ! #30
time for some pics already, haha.
Glad you got 'er gorn.
   / Bought a new SANY SY50U ! #31
Awesome! Glad to hear you are back up and running. Lets see some pictures!
   / Bought a new SANY SY50U ! #32
YES!
Fixed!
YES, 300 amp!
so how can you have any parasitic draw with the master fuse blown?
   / Bought a new SANY SY50U ! #33
YES!
Fixed!
YES, 300 amp!
I'd ask them to order two of those fuses so you have a backup.
   / Bought a new SANY SY50U ! #34
That’s real good news. I’m curious though was the battery, starter, and fuse all 3 bad? Or just the fuse and the tech through the other 2 in for good measure?
Thanks! Will get to pics soon...
I'm down with that. I think the tech will keep a few spares on his truck now. Know I would...
On some level I don't really care, because it's fixed; but I get your thinking. (y)
Here's my understanding so far: sequence most likely was battery went low from little run time and a bunch of short runs of the engine while on and off the ship, trucks on way across the US from left coast, and then a few short runs while being prepped for delivery to me.
Temps were low, when I got delivery, and then I ran her about 6 hours that day. She sat on Sunday, then went to start on Monday, a week ago - no joy.
So, from the slow cranking until it died I immediately thought battery- so I tested it and charged it cautiously - due to sub-freezing temps, when a frozen deeply discharged battery can explode violently and unexpectedly.
Battery showed fully charged, but no results. Did not know of the 300 amp fuse at the time. Tech came, changed out battery and found parasitic draw of 2 amps. He had me turn key to crank- nothing. He was stimmed; then did some diagnostics, and found the blown 300 amp fuse. I think he then removed it but hooked up the 2 wires that were on the top side of the bolt holding the fuse and wires to the positive cable's busbar. I had gone inside while he removed sheet metal and dove into the hunt/removal of the starter. When I returned to the scene he had her spun around and ready to go.
So, as far as I know all three were dead for different reasons. Clearly, to my mind, the 300 amp fuse blew due to the slow cranking when I tried to start her last Monday. I inspected the Bendix gear teeth of the defective starter and found no obvious damage. I don't have any other reasonable logic for the sequence of events, and the starter blowing a 300 amp fuse is pretty weird as far as things go on a new machine, of any type?!
Other plausible explanations are welcomed...
There are two other battery/entire electrical system 'switches' that might have come into play: one the incorrectly labeled battery isolation switch, located above the battery ground post/cable. It turns to lock the electrical system from the battery, hence isolation. BUT the tech said, even though it is supposed to lock it out completely, he believes it does not turn off everything, so maybe it has a delay to allow some items to store settings like the time of day, etc. into memory, so on reboot settings are remembered... It is 'spliced' into the negative side battery cable wiring. And there's a solenoid, also connected into one of the cables to the battery; not sure which one since I was doing my diagnostics not realizing the 300 amp fuse existed and was blown at the time I was circuit testing...
The other master control switch is a big red button under the seat bottom, along side the seat's platform, where the fuse box and other under seat wiring goes to get lost for all time.
This button is big and is intended to be slammed in an emergency, but is not for turning the machine off unless something is wrong, or an accident has occurred, for instance.
Unfortunately, I could not stop the delivery driver from slamming it to demo to me how it works, when I asked him about it. Not saying it caused the fuse blow out since that didn't happen until several days later, but the manual said using the switch under non-emergency conditions could do machine damage, possibly. I hear lawyers in the background helping write all manuals these days, eh?!
I did have the tech add my just bought battery heater pad, and I will add my 'Thermo-cube', (on at 35 degrees F, off at 45 degrees F thermostatically controlled switch) that allows two items to be temp controlled by an extension cord.
The tech liked the idea and told my wife he might get one for his on at dusk, off at dawn truck heater, which costs like $15/day in electric... WOW!
That's way too much $$$ for me...
CM out for now.
   / Bought a new SANY SY50U ! #36
Wow, thanks for the explanation. Looks like you’ve got a good dealer that backs up his products! Great news, enjoy!
Thanks,
You're right, my dealer is Awesome, and his entire team, sales & service.
   / Bought a new SANY SY50U ! #38
4 pages Coyote, 4!
I'm beginning to think that.....
Pictures dude 👍😆
For some reason I thought about this and your new machine and sometimes I won't receive notices on new posts. Tbn shame on you 😆, there were none especially with pictures. 😁
(All the stupid smiley faces mean I'm joking with you)
   / Bought a new SANY SY50U ! #39
Im have a heck of a time getting a new Sany SY16c mini excavator repaired. From day one tracks would not counter rotate. Dealer has tried to repair in 3 times now. Im afraid i have a lemon and Sany is not stepping up to the plate to to fix or replace.. I sure hope you have better luck if you find dealer can not fix
Sorry I've been remiss to TBN, and have not kept up to date answering posts like the one above.
budvoss, you're new to the TBN site and for future reference it's better to start a new thread about your issues with your particular Sany macchine. By posting a new thread more people who may answer are likely to see the thread, instead of your message just being one post in someone else's thread.
Now, for my take on your situation. Don't take an unsatisfactory repair or several attempts to get your machine fixed under warranty as your problem. Make it your dealer's problem. If they refuse to fix it properly, or for some reason, can't fix it - then go over their heads to the Sany corporate representative in your dealer's area.
Post back results- in a new thread you start, now, and let us know how things are going. My impression is that Sany wants, like Kioti does, good rep and happy owner's of their machines. PM me if you have any other questions about your machine you can't get resolved
CM out.
International MaxxForce 6-Cylinder Turbo Diesel Engine with Transmission (A59228)
International...
2012 Kenworth T800 T/A Day Cab Truck Tractor (A55973)
2012 Kenworth T800...
2007 CHEVROLET 3500 DUALLY 4X4 DIESEL TRUCK (A59575)
2007 CHEVROLET...
2009 Sterling Acterra Altec DM47TR Insulated Digger Derrick Truck (A60460)
2009 Sterling...
2022 CATERPILLAR 299D3 SKID STEER (A60429)
2022 CATERPILLAR...
2023 CATERPILLAR 330 EXCAVATOR (A60429)
2023 CATERPILLAR...
