Mahindra 100 hp tractor
   / Mahindra 100 hp tractor #21
Anyone see specs on this machine? I checked the website and no mention of it at all.
   / Mahindra 100 hp tractor #22
The tractors are not available to all dealers yet. They have a small quantity at this point going to a few select dealers. Once we get some volume, they will be more widely available and we would expect some announcements and specs and such.
   / Mahindra 100 hp tractor #23
Why all the hub bub with the Max before it came but not the 100hp machine?
Didn't know if there was a particular reason.
Not like I'm in the market.
Heck I can't even window shop in that big boys realm.
   / Mahindra 100 hp tractor #24
It's a totally different market.
   / Mahindra 100 hp tractor #25
Is the tranny a 12 or 32 speed shuttle? Looked at the TYM version at the last farm show, but IMO the 8560 is a lot more tractor just less engine. I'm not particularly fond of only a 12 speed tranny. Dave how bout you custom build me a 100 hp 8560 with a 32 speed tranny!
   / Mahindra 100 hp tractor #26
Not sure on the tranny speeds as I don't have the data in front of me and I don't have any in stock. As for your 100 HP 8560, I'll get some decals printed up......what would you like, 10060? Looks like a zip code, maybe 9960?
It would seem that the 8560 in 95 HP and then maybe 105 HP would be a nice setup.
   / Mahindra 100 hp tractor #27
Come on now, you know that they are working on one. How much longer? :drool: Any chance of one in 2013 at all, or is it going to be 2014? :( A 16 speed hydraulic shuttle is good enough for me. ;)
   / Mahindra 100 hp tractor #28
I'm hoping we have the 100 HP at the Tulare show, anything else is top secret. Which actually means I have no idea, but sounds more mysterious.
   / Mahindra 100 hp tractor #29
:cool2: :cool2: The 100hp 60 series? :confused3: Any chance that it will have a cab? :drool: Man now I wish that I hadn't asked. Is the expo next week? :rolleyes: :drool: Just kidding, I know that it is 47 days away. ;)
   / Mahindra 100 hp tractor #30
But who's counting. :D
I hope more and more manufacturers start coming out with the hydraulic shuttle shift transmission. Mahindra doesn't have one yet correct? Is the 8560 hydro shuttle shift?
   / Mahindra 100 hp tractor #31
No, the 60 series is just plain 12x12 shuttle. No hydraulic shuttle. :( The 35 series has the hydraulic shuttle option though. :thumbsup: Mahindra needs to make just a few more improvements, or at least options and they will be right there with everyone else IMO.
I REALLY like my Mahindra 7520, but there are times when it would be nice to have a 16x16 tranny. Ah, and a cab with a few more ponies under the hood. ;)
   / Mahindra 100 hp tractor #32
How much extra weight do you have hanging on your 7520? More weight means you can now use more HP. You would then add more weight and need more HP. We know your type.....;)
I agree on the 16x16. Can't have too many gears or too much power. How does that country western song go? "No girl too pretty, no car too fast?" Applies to tractors as well.
   / Mahindra 100 hp tractor #33
My tractor with no loader is at 10,000lbs. For what I use it for, it is ballasted to the max for the power available. I really need something 100+ hp that weighs 14k+. This would really cut my time down in the fields to be able to use the implements that I now use behind the Cat. There just isn't enough time for all the weekend ranch work. :(
   / Mahindra 100 hp tractor #34
You would then just buy more property and need yet a bigger tractor. Face it, there is no end to this. :cool2:
   / Mahindra 100 hp tractor #35
I would love a 100 or 105 hp MAHINDRA with a backhoe that could handle that hp.
I got a new dual tandem trailer so I can load mind up like Brian's.
hugs, Brandi
   / Mahindra 100 hp tractor #36
hugs, Brandi
I think Brian's tractor with loader is at nearly 12K lbs, add a 511 backhoe and you are at about 14k lbs. I'd say you would be close to max GVWR even with your tandem dually. I think our tandem dually is rated at 20k on the axles, and we can put a few thousand on the pin. The trailer weighs 7k with the chains and ramps and all, so if we load perfectly we can get about 16K on the deck, but that is maxing the tandems and the rear axle of our pickup. And it is hard to get the axles loaded just as you want them unless you have scales handy.
   / Mahindra 100 hp tractor #37
Dave,
My 511 BH weighs 1600 pounds without a bucket. Buckets are 75-150 pounds or so. The Big RED Beast is 11,300 pounds without loaded tires, with the backhoe. I have no wheel weights. As is......it was 100 pounds under gross weight on my 20 foot 14,000 pound gooseneck. My dual tandem is rated for 22,000 (2000 on the hitch pin, so it is like yours) pounds and weighs 7400 (on the title). I need to take it and weight it for what weight is on the axles, emtpy.
So now, on paper, I can haul 14,600 pounds on it. So I can add 3300 pounds to the Big RED Beast in weight or attachments or another machine. I bought the dual tandem to haul the grapple AND the loader bucket, as that overgrossed my 20 foot GN by about 300 pounds. The 24 foot deck plus 5 foot dovetail gives me more room to move the load around and balance it out.
So it seems I could load all 4 tires with rim guard for an additional 1840.4 pounds for a total of 13,140.4 pounds of tire loaded Big RED Beast!
I have painted marks on the deck of the dual tandem to know where to park the Big RED Beast on it to level it out. Once I know the true emtpy weight on the axles, I will paint on more marks. I also put two white marks on the deck's edge to show where the axles are below.
Brian, how much in wheel weights do you have on your 7520?
hugs, Brandi
   / Mahindra 100 hp tractor #38
864lbs of wheel weights (6 sets) and double whatever the std amount is for the front. ( I have forgotten what that amount is. :eek:) I know that it sure is nice to have the loader off and have those front weights on when doing field work. :thumbsup: Remember that I also have all 4 tires filled. This is the weight that I have to have to be able to get the maximum capabilities out of the 7520. ;)
   / Mahindra 100 hp tractor #39
Thanks for the photos and weight amounts, Brian.:) The New Holland blue paint job still looks good:2cents::rolleyes:
hugs, Brandi
   / Mahindra 100 hp tractor #40
First look at the new mFORCE tractor. The mFORCE comes with a 5 year warranty standard, like all Mahindras. Sales have been great and owners seem to be very pleased with the new mFORCE tractors.mFORCE Series.jpgmForce_profile_view.jpg
2016 HAMM H7i SMOOTH DRUM ROLLER (A60429)
2016 HAMM H7i...
(2) NOS-8 LUG- 7000Ib 74SC-93 HUB FACE DROP AXLES (A60432)
(2) NOS-8 LUG-...
(4) ROADGUIDER QH100 235/80R16 TIRES (A60430)
(4) ROADGUIDER...
KUBOTA SVL75 ENCLOSED CAB (A52706)
KUBOTA SVL75...
BUYERS PREMIUM & PAYMENT TERMS (A59904)
BUYERS PREMIUM &...
2014 Chevrolet Silverado 4x4 Crew Cab Pickup Truck (A56858)
2014 Chevrolet...
