Ballast made some rear wheel weights
/ made some rear wheel weights #1
OrangeFloyd
Pac N\'West
Kubota B7510
Since my boxblade as a ballast becomes a "non-ballast" when used, I have designed some rear wheel weights. Pretty simple, old idea, should work well. 1/2" plate tapped-out to accept 1" (b7) threaded rod, half-nut and split ring lock washer on rear. Plate holds fast to wheel with grade 5 cairrage bolts. Additional plates added to original that stays in place. About 20# per plate. Probably add 3 to first and see how it goes. 1" nut-washer-lock to hold other plates on.
-OF
one more pic
3rd, last pic
/ made some rear wheel weights #4
OrangeFloyd pretty simple and straightforward construction, good job. And the best part is they are sure to give you increased stability and traction as well.
brentbx22- I will try to install tomorrow, then take pics. Hurting a bit for time though, got a trip to Bandon Dunes , Oregon starting on Saturday for a little golf with the boys. If not pics tomorrow then as soon as I get back.
S'pose this topic should have gone in another category, yikes!
-OF
2014 Dodge Grand Caravan Van (A66738)
2014 Dodge Grand...
Assortment of John Deere Gator Parts (A64912)
Assortment of John...
2023 WALLACE-THE ROOSTER ROOT PICKER PINTLE HITCH (A65054)
2023 WALLACE-THE...
2011 UNKNOWN FRAC PUMP (A67714)
2011 UNKNOWN FRAC...
2023 Wallenstein BXTR6438 Towable Woodchipper (A66734)
2023 Wallenstein...
2019 Cadillac Sayers and Scovill 70IN Limo w Only 7729 Miles (A63689)
2019 Cadillac...
