Ballast made some rear wheel weights
/ made some rear wheel weights #1
OrangeFloyd
Pac N\'West
Kubota B7510
Since my boxblade as a ballast becomes a "non-ballast" when used, I have designed some rear wheel weights. Pretty simple, old idea, should work well. 1/2" plate tapped-out to accept 1" (b7) threaded rod, half-nut and split ring lock washer on rear. Plate holds fast to wheel with grade 5 cairrage bolts. Additional plates added to original that stays in place. About 20# per plate. Probably add 3 to first and see how it goes. 1" nut-washer-lock to hold other plates on.
-OF
one more pic
3rd, last pic
/ made some rear wheel weights #4
OrangeFloyd pretty simple and straightforward construction, good job. And the best part is they are sure to give you increased stability and traction as well.
brentbx22- I will try to install tomorrow, then take pics. Hurting a bit for time though, got a trip to Bandon Dunes , Oregon starting on Saturday for a little golf with the boys. If not pics tomorrow then as soon as I get back.
S'pose this topic should have gone in another category, yikes!
-OF
2014 International Durastar 4300 S/A Dump Truck (A61573)
2014 International...
Duratech HD 8 Tub Grinder (A62613)
Duratech HD 8 Tub...
2017 Ford F-150 Pickup Truck (A61573)
2017 Ford F-150...
2016 GMC SLT 3500 Pick Up (A62613)
2016 GMC SLT 3500...
TERRA TRACK TRACKED WORK  VEHICLE
TERRA TRACK...
2004 AGCO Gleaner 3000 Corn Header (A61307)
2004 AGCO Gleaner...
