Ballast made some rear wheel weights
/ made some rear wheel weights #1
OrangeFloyd
Pac N\'West
Kubota B7510
Since my boxblade as a ballast becomes a "non-ballast" when used, I have designed some rear wheel weights. Pretty simple, old idea, should work well. 1/2" plate tapped-out to accept 1" (b7) threaded rod, half-nut and split ring lock washer on rear. Plate holds fast to wheel with grade 5 cairrage bolts. Additional plates added to original that stays in place. About 20# per plate. Probably add 3 to first and see how it goes. 1" nut-washer-lock to hold other plates on.
-OF
one more pic
3rd, last pic
/ made some rear wheel weights #4
OrangeFloyd pretty simple and straightforward construction, good job. And the best part is they are sure to give you increased stability and traction as well.
brentbx22- I will try to install tomorrow, then take pics. Hurting a bit for time though, got a trip to Bandon Dunes , Oregon starting on Saturday for a little golf with the boys. If not pics tomorrow then as soon as I get back.
S'pose this topic should have gone in another category, yikes!
-OF
GRACO KING XL45 PROTECTIVE COATING SPRAYER (A67714)
GRACO KING XL45...
2018 Ram 1500 Reefer Meal Delivery Truck (A64556)
2018 Ram 1500...
High End Mini Golf Cart (A64912)
High End Mini Golf...
CATERPILLAR ENGINE (A67714)
CATERPILLAR ENGINE...
2017 Ford F-550 Altec AT37G 37ft. Insulated Bucket Truck (A66736)
2017 Ford F-550...
2012 INTERNATIONAL 4300 4X2 S/A UTILITY BODY TRUCK (A66091)
2012 INTERNATIONAL...
