lower link cat 1 pins
/ lower link cat 1 pins #1
spo307
Levittown & Long Eddy NY
kubota L4400
do these look like the correct lower link pins? width form hole to nut?
Lower Link Pin, Category 1 Adjustable, 7/8 in. dia. - 0268420 | Tractor Supply Company
/ lower link cat 1 pins #2
There is many different styles...the ones you listed are "adjustable" because they have that thin nut on the inside, there is also the type that has a flange there instead.
The ones you listed will work great...use loctite on the threads.
/ lower link cat 1 pins #4
I would not use weld on pins-if you can find them, I have never seen them. Do you have a TSC nearby? They have the different styles in stock usually.
no i was om there website, ur saying it is threaded but has a metal stop instead of a nut
/ lower link cat 1 pins #6
Hello
Put this number in the search box at TSC and I think this is what you want.
07020800U
$2.99
DSP 900 Balancer with Split Weight (A63689)
DSP 900 Balancer...
MacDon 963 Draper Header (A63688)
MacDon 963 Draper...
2020 Deere 544L (A60462)
2020 Deere 544L...
Wacker Neuson PT2 Water Pump (A59228)
Wacker Neuson PT2...
1997 Duraco Dura Patcher 81DJ Towable Asphalt Patcher (A64194)
1997 Duraco Dura...
2025 Kivel 48in Forks and Frame Skid Steer Attachment (A61572)
2025 Kivel 48in...
