lower link cat 1 pins
/ lower link cat 1 pins #1
spo307
Levittown & Long Eddy NY
kubota L4400
do these look like the correct lower link pins? width form hole to nut?
Lower Link Pin, Category 1 Adjustable, 7/8 in. dia. - 0268420 | Tractor Supply Company
/ lower link cat 1 pins #2
There is many different styles...the ones you listed are "adjustable" because they have that thin nut on the inside, there is also the type that has a flange there instead.
The ones you listed will work great...use loctite on the threads.
/ lower link cat 1 pins #4
I would not use weld on pins-if you can find them, I have never seen them. Do you have a TSC nearby? They have the different styles in stock usually.
no i was om there website, ur saying it is threaded but has a metal stop instead of a nut
/ lower link cat 1 pins #6
Hello
Put this number in the search box at TSC and I think this is what you want.
07020800U
$2.99
JCB 510-56 TELESCOPIC FORKLIFT (A64279)
JCB 510-56...
2012 John Deere 328D Compact Wheel Loader Skid Steer (A61572)
2012 John Deere...
48"LOADER FORKS/FORK EXT (A64281)
48"LOADER...
1986 CATERPILLAR D4H HI-TRACK CRAWLER DOZER (A64279)
1986 CATERPILLAR...
2010 Doyle 32ft Tender Trailer - Kubota Diesel - Stainless Steel Augers - Recently Refurbished (A61307)
2010 Doyle 32ft...
429835 (A61166)
429835 (A61166)
