lower link cat 1 pins
/ lower link cat 1 pins #1
spo307
Gold Member
Levittown & Long Eddy NY
kubota L4400
do these look like the correct lower link pins? width form hole to nut?
Lower Link Pin, Category 1 Adjustable, 7/8 in. dia. - 0268420 | Tractor Supply Company
/ lower link cat 1 pins #2
There is many different styles...the ones you listed are "adjustable" because they have that thin nut on the inside, there is also the type that has a flange there instead.
The ones you listed will work great...use loctite on the threads.
/ lower link cat 1 pins #4
I would not use weld on pins-if you can find them, I have never seen them. Do you have a TSC nearby? They have the different styles in stock usually.
no i was om there website, ur saying it is threaded but has a metal stop instead of a nut
/ lower link cat 1 pins #6
Hello
Put this number in the search box at TSC and I think this is what you want.
07020800U
$2.99
2015 KUBOTA F3990 MOWER (A66091)
2015 KUBOTA F3990...
2018 JOHN DEERE 650K LGP CRAWLER DOZER (A64279)
2018 JOHN DEERE...
2014 International PayStar 5900i T/A 24ft Flatbed Truck (A64194)
2014 International...
WESTINGHOUSE PORTABLE ARC WELDER (A64276)
WESTINGHOUSE...
2016 Ford Escape SUV (A64557)
2016 Ford Escape...
Front Tank Bracket (A64126)
Front Tank Bracket...
