looking for rare metric bolts
   / looking for rare metric bolts #31
belmetric may work! For some reason they did not come up in my search.
LS parts may work, half of the factory bolts where I did not plate are longer so I may be able to order 16 of them. Thanks everyone for your input, I will give update when I know more.
Isn't Belmetric the $45/bolt place?
   / looking for rare metric bolts #32
Is it possible to use allthread cut to size and nuts for your application ?
Web Parts Catalog.
See where the factory frame goes from double to single - that is where it cracked and the single plate I doubled to match the front. So I should be able to get 16 of those id #10.
Thanks everyone!
   / looking for rare metric bolts #34
Web Parts Catalog.
Thanks everyone!
You may want to triple check your bolt thread pitch.
I checked the parts catalog and they list M14x1.5 which it a lot easier to find. M14x1.25 is pretty much an odd size and most likely a specialty thread of some sorts.
   / looking for rare metric bolts #37
M14 x 1.25 is very close to 9/16-18. It is about .011" smaller and the pitch is about .006" finer. You could probably get away with tapping 9/16-18. In fact, are you sure that's not what it is? An M14 x 1.25 bolt might thread into a 9/16-18 hole just because it is smaller. If it was my tractor I would be tempted.
Eric
2007 Ford Ranger Pickup Truck (A50323)
2007 Ford Ranger...
2019 KEESTRACK K6 SCALPING SCREENER (A51246)
2019 KEESTRACK K6...
1985 Ford Ltl9000 Tender Truck (A52748)
1985 Ford Ltl9000...
KUBOTA ZD1211 (A53084)
2025 20ft. G70 Cargo Transport Chain (A51692)
2025 20ft. G70...
