looking for rare metric bolts
   / looking for rare metric bolts #31
belmetric may work! For some reason they did not come up in my search.
LS parts may work, half of the factory bolts where I did not plate are longer so I may be able to order 16 of them. Thanks everyone for your input, I will give update when I know more.
Isn't Belmetric the $45/bolt place?
   / looking for rare metric bolts #32
Is it possible to use allthread cut to size and nuts for your application ?
Web Parts Catalog.
See where the factory frame goes from double to single - that is where it cracked and the single plate I doubled to match the front. So I should be able to get 16 of those id #10.
Thanks everyone!
   / looking for rare metric bolts #34
Web Parts Catalog.
Thanks everyone!
You may want to triple check your bolt thread pitch.
I checked the parts catalog and they list M14x1.5 which it a lot easier to find. M14x1.25 is pretty much an odd size and most likely a specialty thread of some sorts.
   / looking for rare metric bolts #37
M14 x 1.25 is very close to 9/16-18. It is about .011" smaller and the pitch is about .006" finer. You could probably get away with tapping 9/16-18. In fact, are you sure that's not what it is? An M14 x 1.25 bolt might thread into a 9/16-18 hole just because it is smaller. If it was my tractor I would be tempted.
Eric
MI-T-M PRESSURE WASHER (A52472)
MI-T-M PRESSURE...
2011 Ford Edge SEL SUV (A50324)
2011 Ford Edge SEL...
2007 IH 4300 Dump Truck (A47384)
2007 IH 4300 Dump...
1994 Prevost Liberty Coach Motorhome (A51694)
1994 Prevost...
2010 MQ POWER 25KW GENERATOR (A52472)
2010 MQ POWER 25KW...
