looking for rare metric bolts
   / looking for rare metric bolts #31
belmetric may work! For some reason they did not come up in my search.
LS parts may work, half of the factory bolts where I did not plate are longer so I may be able to order 16 of them. Thanks everyone for your input, I will give update when I know more.
Isn't Belmetric the $45/bolt place?
   / looking for rare metric bolts #32
Is it possible to use allthread cut to size and nuts for your application ?
Web Parts Catalog.
See where the factory frame goes from double to single - that is where it cracked and the single plate I doubled to match the front. So I should be able to get 16 of those id #10.
Thanks everyone!
   / looking for rare metric bolts #34
Web Parts Catalog.
Thanks everyone!
You may want to triple check your bolt thread pitch.
I checked the parts catalog and they list M14x1.5 which it a lot easier to find. M14x1.25 is pretty much an odd size and most likely a specialty thread of some sorts.
   / looking for rare metric bolts #37
M14 x 1.25 is very close to 9/16-18. It is about .011" smaller and the pitch is about .006" finer. You could probably get away with tapping 9/16-18. In fact, are you sure that's not what it is? An M14 x 1.25 bolt might thread into a 9/16-18 hole just because it is smaller. If it was my tractor I would be tempted.
Eric
1999 MACK CH613 WATER TRUCK (A50854)
1999 MACK CH613...
2017 KOMATSU PC228USLC-10 EXCAVATOR (A51242)
2017 KOMATSU...
2014 Volkswagen Passat Sedan (A50324)
2014 Volkswagen...
2022 FREIGHTLINER M2 24FT BOX TRUCK (A51222)
2022 FREIGHTLINER...
2010 FORD F150 WORK PICKUP TRUCK (A51222)
2010 FORD F150...
2012 MACK GU713 DUMP TRUCK (A51406)
2012 MACK GU713...
