Lock n lube grease gun fitting
   / Lock n lube grease gun fitting #1
Frankenkubota
Elite Member
Carthage NC...Deep in the woods
Kubota MX 5800, SkidPro 4 in 1, Ratchet rake, SkidPro pallet forks
So sorry, I know there is a lock n lube thread but when I search I get threads about tires locking up etc.
I do not interface well with technology, I AM A LUDDITE!
With that said, my new lock n lube fitting quit on me. It was working fine, had 2 more zerks to do and noticed the grease coming back at me, not going into the fitting.
That usually means I had not made the connection properly. Nope.
Everything seemed to hook up fine but, the grease keeps coming back at me!
I知 curious, is there some kind of pin or something in the lock n lube the depresses the spring loaded ball bearing in the zerk? Or is it the pressure? I tried 3 different known working fittings so......
I知 going to tear it apart but, thought I壇 ask the experts first.
Made in S. Africa. When痴 the last time you bought anything made in S Africa, except diamonds!
Multi Gracie!
   / Lock n lube grease gun fitting #2
I had a love/hate relationship with mine for a year. When it finally quit working I installed the rebuild kit that came with it. It has worked much better since then. I almost gave up on putting the kit in because it was such a bear to get apart. Had to clamp the nut base in a vise and use vice grips on the barrel but it finally gave in.
When it dies again I won't be replacing it.
   / Lock n lube grease gun fitting #3
Al lot of time when I have had grease coming back at me, I find the little ball in zerk as seized to housing... Don't have lock-n-lube but considering it... But over years I have had to free up ball in zerks to get it to accept grease.....
Dale
   / Lock n lube grease gun fitting #4
Got any good tricks to share for freeing up that ball?
I forgot about the rebuild kit. As far as ceased zerks, maybe not because I did one, normal, next one, grease came back at me, immediately went to the one I’d just done, same problem so, probably failed gadget.
Virtually every gadget I get works good for 6 months, then ...... not so much.
This forum is amazing. As always, many thx
   / Lock n lube grease gun fitting #9
YUP ......it is called.....Grease Joint Rejuvenator
Original Equipment Manufacturer (OEM)
Not cheap, but it works!
$45 @ Northern Tool, $50 @ TSC
Already own one of those. They are handy, but don't free up every joint. One of these days I'll lay in a supply of replacement zerks in various sizes and orientations so I can just replace the stubborn ones.
   / Lock n lube grease gun fitting #10
Sometimes it is not actually the zerk that is the problem.
Sometimes grease has hardened, or dirt has accumulated beneath the zerk.
That is when the Grease Joint Rejuvinator is most appropriate.
   / Lock n lube grease gun fitting #11
When I have a problem with a grease fitting, I replace it! :cool: I have several of those cases of fittings. It's not worth fighting with them. I've also had two of the Lock-n-Lube copies for about 4-5 years. No problems. I've noticed some fittings "leak" but they look undersized so a quick grip adjustment usually fixes that. Those leaky fittings must be metric. :rolleyes:
   / Lock n lube grease gun fitting #12
Oh sure. Drive all that dried up grease and dirt down into the part! That will fix it. :confused:
   / Lock n lube grease gun fitting #13
What is your solution when the (new) replaced grease fitting will not accept grease either?
   / Lock n lube grease gun fitting #14
I got lucky there.
At a gov't sale I bought a nice assortment in a 30 or so tray kit for $10.00.
Just about every angle and thread styles made.
I separated the assortment in 2 and sold the 1/2 to a mechanic buddy for $10.00.
He was very pleased.
LOL, then used the 'tray kit' for transporting my assortment of wood screws to job sites.
Guess that's called a 'win win'.
   / Lock n lube grease gun fitting #15
Probably the most common reason a fitting won't take grease is having pressure on the side of the pin the fitting is on. Often just moving the bucket or whatever to relieve that pressure is all that is needed to get grease to flow.
Generally if I encounter a fitting that won't take grease I remove the fitting, dig all the dried grease out of the hole with a scribe, and stick the removed fitting on the grease gun to verify it operates. It is rare since I service all my equipment and use grease that doesn't harden quickly. I do on occasion have to fight with a pin here or there on my backhoe. Seems forcing things down into the dirt can have consequences.
   / Lock n lube grease gun fitting #16
^^^agree with this^^ I always try to grease when the pressure is opposite from normal wear so the grease is where it will do the most good.
   / Lock n lube grease gun fitting #17
I have a L'nL. Works great where you need a third hand. DOES NOT work on many of the zerks on the FEL. Many zerks on the FEL are in a recessed "pocket". The outer diameter of the L'nL is greater than the diameter of the recessed pocket. Back to one of my standard guns.
I've had one zerk that refused to take grease. I replaced it. I have one zerk that is ALWAYS a pain in the azz. Raise the upper jaw of the grapple - life is good.
I have two multi-multi packs of grease zerks. About 20% will ever fit and be used.
   / Lock n lube grease gun fitting #18
They make a longer version of the standard one that will fit into most spaces.
   / Lock n lube grease gun fitting #19
Then it's not the grease fitting that's bad. Fix what's bad. Ignoring the real problem won't make it go away. :confused3:
   / Lock n lube grease gun fitting #20
my LnL clone has a 5/8" OD, and that did not fit all of my recessed zerks. Sometimes it was cuz the zerk was off center. Other times the ID of the pin depression was a hair less than 5/8".
My solution was to remove the zerk, then drill the depression with a 5/8" drill.
Some equipment has pivots that use removable sleeve bearings, and the zerk is perpendicular to the pin. If those don't take grease and the zerk is good, the problem is usually the sleeve has spun and blocked the hole.
2017 FREIGHTLINER CORONADO SD122 DAY CAB (A56138)
2017 FREIGHTLINER...
2017 KALMAR OTTAWA T2 4X2 SPOTTER TRUCK (A60430)
2017 KALMAR OTTAWA...
2020 Peterbilt 367 Weldco Hydra-Lift WHL45TC100 45 Ton Tri Axle Telescopic Crane Truck (A55973)
2020 Peterbilt 367...
2020 DRAGON ESP...
2020 CATERPILLAR CB13 SMOOTH DBL DRUM ROLLER (A60429)
2020 CATERPILLAR...
2019 Ram 3500 HD (A56435)
2019 Ram 3500 HD...
