Tires Liquid Filled Tires
/ Liquid Filled Tires #1
tensaw12
Is there any disadvantage to filling your tires? Would they puncture more easily with the added weight?
/ Liquid Filled Tires #2
I think the only 'mechanical' disadvantage is if you want a light tractor. For some people a light tractor is more important than a heavy one. The weight of the fluid also needs to be taken inot account when trailering your tractor.
I think other disadvantages mostly have to do with your choice of fluids.
/ Liquid Filled Tires #3
I'll give it a shot...
Answering your 2nd question first, theoretically, yes. But in the real world, no. Filled tires take up air space inside the tire. Liquid does not compress and "air" does. So theoretically, with less air to compress, a spike may induce a slight increase in pressure like having a "harder" more full, more pressure in the tire. But this would be minuscule in real life so I don't think it would make any difference at all in real life....diddly squat.
For all the advantages gained by filling your tires, the disadvantages, ironically, come from getting the gains. That is, a filled tire with a rupture would cause a mess that an unfilled tire does not. Maybe the added weight disrupts your lawn surface more? There's an associated cost, of course, to fill the tires. etc etc. Those kind of disadvantages if you want to call them that, so in my book, they are not really disadvantages. LOL ... That's sorta like buying food to eat and claiming the disadvantage is you have to pay for it. The gains, however, far out weigh those disadvantages. More weight, more stability, way better traction. All this equates to better overall performance and safety for your tractor. Lets you utilize the hp and power your tractor has better to a certain degree.
I'm sure others will chime in with more info...
George and Rob,
Thanks, to both of you, for your help.Do, either of you, have a fluid of choice?
Thanks
Ray
/ Liquid Filled Tires #5
Hi Ray,
There are several choices for you, depending on your personal preference. Some liquids have an environmental effect if spilled or a puncture occurs and some do not. Some are are more corrosive to the rims than others. Calcium Chloride fill offers a heavier pounds per gallon, depending on the mixture. Then there is windshield wiper fluid that is used and beet juice (Rim Guard) or a mixture of anti-freeze with water. They all offer the basic gains of loaded tires with different side effects regarding spillage and corrosion and resistance to freezing. Personally, I filled all 4 tires with anti-freeze and water and I did it myself.
Rob. Again, thanks for your help.
What ratio did you use?Anti Freeze to Water? Does it make a difference.
Thanks Again
Ray
/ Liquid Filled Tires #7
Well, it depends on how cold it gets where you live. You'll need to determine the number of gallons each tire will hold and the freezing protection you need for that mix. I live in Southern California and it rarely gets below freezing so I used 3 gallons in the rears and 1 in the fronts. Here are 2 links to read ... some information and a chart. It tells you how much weight a filled tire becomes depending on tire size and also a little more on the subject.
Hope that helps....
Tire Ballast Management
Filling Farm Tires
/ Liquid Filled Tires #8
I see a 3rd disadvantage. If you decide to remove the fluid from
your tires, it is difficult. The first 75% is not so bad, but the rest
requires wheel removal and breaking the bead. Plus it should be
collected and properly disposed of if it is antifreeze.
A tractor that needs to be heavy sometimes for traction or balance,
and lighter sometimes for transport should probably not use
tire fluid IMO. Weight can always be added/removed using an
implement or ballast box.
Thanks, to all that replied.:)
Ray
/ Liquid Filled Tires #10
I don't know what size tires you will be filling but here's a webpage I made showing how I filled the tires on my JD 2305, if it helps .
TireBallast
Deerfoot,
Thanks for your help. Your information REALLY!! helped.
Ray:)
/ Liquid Filled Tires #12
My pleasure Ray. I'm glad it helped. Good luck with filling your tires!
Paul
/ Liquid Filled Tires #13
TireBallast
Nice job. Like the way you used 2x4s to break the bead.
Unfortunately, the filled tires on my MF-135 are gigantic compared to those on your JD. And they have inner tubes. No way I can get those on and off the axle by myself. So I plunked down about $15 at NAPA for an adapter that screws onto the tire's Schrader valve and allows liquid or air to be pumped in. Takes a long time to fill my tires doing it this way compared to your approach, but I'm stuck with those wide tube tires unless I want to drop bucks into another pair.
/ Liquid Filled Tires #14
I've used filled tires for over 30 years and have never had trouble getting out all of the fluid. Just put the valve stem on the bottom side and pump it out. I let a tire man do mine since he has all the equipment. I used to use Calcium but now all I use is RimGuard. It's heavy, does not corride and is enviromentially safe.
I would not use a loader without loaded tires and a heavy 3 pt atachent.
Andy
/ Liquid Filled Tires #15
Andy
Pump it out? How? A hose small enough to fit inside the valve stem
would be very small indeed. If you have to take your tractor to a
shop for a job like this, then that is also a negative.
As for wheel weight versus ballast behind the rear wheels, this subject
has been covered many times. If your front tires are AGs and you use a
loader without ballast behind the rear wheels, then the the capacity of
the front tires will be exceeded. A user will be tempted to go without
ballast on the 3-pt if he has filled tires and/or wheel weights. It is good
that you use both.
/ Liquid Filled Tires #16
You don't need to pump it out. Take the tire and wheel off the tractor. Position it so the valve stem is at its lowest point, open the valve stem and it gushes out. If the pressure falls and there is still water inside, fill it full of air and do the same thing again. Repeat a couple of times and most of the fluid should be out.
2007 Kia Amanti (A66408)
2007 Kia Amanti...
14ft Flatbed Truck Body (A59228)
14ft Flatbed Truck...
New/Unused Landhonor Gantry Crane (A65583)
New/Unused...
Midwestern Industries MEV Screen Model MEV 5X10-2 (A63689)
Midwestern...
CATERPILLAR TL642D TELESCOPIC FORKLIFT (A62129)
CATERPILLAR TL642D...
Year: 2007 Make: Ford Model: F-250 Vehicle Type: Pickup Truck Mileage: 77,977 Plate: Body Type: 4 (A61573)
Year: 2007 Make...
