Lights/shackles Phase #1
/ Lights/shackles Phase #1 #21
Paul:
You've probably already done this but incase you haven't, it's a good idea to put up signs asking everyone to smile. Our's read "Smile we want to photo your best side".:laughing:
Our next door neighbour was a Calgary city policeman and he said that cameras were without a doubt the best deterrent for crime.:thumbsup:
Cheers.
Glenn.
Naah just get a sign like this.
/ Lights/shackles Phase #1 #24
I keep a couple of shackles on my tractor for "just in case" as well. I put an o-ring on the pin and a slight countersink on the shackle so when the pin is hand tightened the o-ring gets crushed just a little bit. That way you can leave the pin finger tight and the vibrations will not loosen them up (and loose them).
I would copy your design but the front grill has to be removed when the sub frame for the front blower gets mounted.
I have a "Bird" sticker on my hardhat. It consists of five fingers with the middle one fully extended, and the rest retracted. :laughing:
:laughing: Matt my sticker is a little less graphic. Here's mine :D
Good idea on the shackle pins. I just put one removable electrical tie rap through mine preventing the bolts from backing out.
/ Lights/shackles Phase #1 #26
I thought parrots were tropical. I figured it would be a trained puffin in your neck of the woods. :laughing:
/ Lights/shackles Phase #1 #27
4shorts,
Nicely done ! I think Kubota should take a couple lessons from your playbook. Your rig looks outstanding.
Well Matt it's been tropical here the last few days :D No puffin around my shop :laughing:
4shorts,
Thank you very much. Nice to hear that you enjoyed seeing it. Appreciate you commenting :thumbsup:
/ Lights/shackles Phase #1 #30
I really like this one also.....kinder version of the one I have on the barn.
Here in Texas we do have our share of characters. My neighbour up the road has a small welding shop. The sign on his door reads "If you can read this......then you are within range". Tends to keep undesirables away.
By the way....Happy Labour Day y'all........have a safe long weekend.
Ha! I like the one on the welding shop :laughing: Hope your having a great weekend as well my friend.
/ Lights/shackles Phase #1 #32
Great work Paul !:thumbsup:
I love the LED work lights on the blower , I looked into putting them on my plow truck but ended up with halogen. I friend put them his truck and hates them, they don't melt the snow and he has to get out and clean them off all the time, I never thought about that !
Ya that's one of the disadvantages of LED lighting, they run cool. It's been a big beef with truckers as well using them on the back of there trailers. Once they get snow on them it don't melt off. As for the ones on the chute. I figured having them there was better than not having them at all. I can always go with a set of wipers on them like Volvo had on there headlights some years ago :thumbsup: Thanks.
Or put electric heaters on them similar to what some outside mirrors on cars have now.
Ya. Could do that but if it comes down to it being a real problem I'll just remove them. Easy on, easy off. Problem solved :D
/ Lights/shackles Phase #1 #37
I think at some point you loose the advantage of the low power draw of LEDs. :laughing:
1995 Peterbilt 379 Tri-Axle Dump Truck (A61573)
1995 Peterbilt 379...
CAT 953C Cab (A68134)
2018 Ford E-450 Shuttle Bus (A61573)
2018 Ford E-450...
SOUTHERN FRAC MANIFOLD (A68842)
SOUTHERN FRAC...
HONDA Plate Compactor (A64553)
HONDA Plate...
JOHN DEERE 6420 TRACTOR (A65054)
JOHN DEERE 6420...
