Lighting question
/ Lighting question #21
There would be a big cost difference, wire is very expensive right now. We all agree, and I have said, he should run some real service back there. As I stated, if it was me, I would run #2-3, I even have some #000 I can make him a deal on, that ought'a make you guys happy. And hopefully something like that is what he will decide to do. Though he seems to be conspicuously absent in this discussion. However, if for what ever reason, he is going to tap an existing circuit, just to run some lights, which is his stated intention. Then going overboard doing it is senseless.
/ Lighting question #22
the diff between 12/2 and 12/3 for 250 feet is 60 dollars .for so that a big diff.if it was me i would only want to do it once.you have to remebber when there is a voltage drop the amps goes up ,.which put a strain on everything ,your bulb wouldnt last as long .it would shorten the life of the ref.you can do what ever you want ,but thats what i would do .ray are you a elertrian ?im for 27 year so i think i know a thing or to .thats my 2 cents
/ Lighting question #23
The original poster wants to hook up his lights to an EXISTING circuit in his barn which is probably 12g.
Using these parameters, it would be useless to run #6 wire as lovemytoys suggested, or #2 or #000, if you are just going to hook it up to an existing 12 g wire.
This is why I suggested using 4 100w HPS lights instead.
By the way, my arena is 100 yards from my barn also, and I have 800 watts of HPS bulbs working decently on 240 volts and I have 12/2 wire. :)
/ Lighting question #24
220v is the way to go.when i said #6 wire i meant all the home not to tap into his existing circuit.you know it and i what he needs now isnt what he need in a week or month or 2.if you are digging a trench do it once and get it over with
/ Lighting question #25
The "big difference" statement was in reference to:
wedge40 said:
With a panel out at the arena you can run your lights and if you need something else once in awhile you have the extra to do it. I'm not sure what the cost difference would be though.
Meaning, the difference between running one circuit, and running enough service to have a separate panel.
lovemytoys, we either seem to be having trouble communicating or you just want to argue. I can't seem to find any common ground with you even though, I also suggested the 12-3 wire, your apparently for, early in the thread.
Your major point of contention seems to be over using 12-2, I have suggested it will work in this case, even though I stipulated, it is not by the book. The reason I said it will work, is because I have done it. You have said, that you believe it will not work based on you experience.
In the interest of peace and harmony, can we at least, agree to disagree?
/ Lighting question #27
Soundguy said:
Hate to burst any bubbles here.. but at least for incandescent lamps.. we are looking at a fixed resistance that becomes stable when the filament is hot... that's the 1 fixed variable of ohms law you can then plug the rest in and play.... use a fixed 'r' and plug in different values of 'e'
Remember.. wattage is not constant... a 12v car battery and a house outlet don't make a 100w 120v bulb glow the same... by some of the logic I've seen thrown around here... they would glow the same.. but the car battery would be sourcing some big amperage....... which.. in practice... it won't.... due to the resistance of the filament.. once it settles down..
soundguy
soundguy I think you and I are trying to say the same thing. Lower voltage on a bulb will use less wattage, draw less amps put out less light and heat and the bulb will last longer.....Been checking and setting voltage on bulbs for forty years.......Larry
/ Lighting question #28
I think it's a real bad idea to extend this circut 333 feet, add 4-7 amps of use way out there, and have a fridge as well as 3 more recepticals ALL on the same line, which we do not know if it is a 14 or 12 ga wire....... And we don't know how long the current wire run is either.....
It is not a good idea at all. Too many unknowns.
If it is a 12 ga with 20 amp breaker, it might work. But not a good idea.
If it is 14 ga which is 15 amp - it's is way out of bounds.
The trench & the time is most of a person's money. Do it right, get 20 amps out there on it's own, so you can have a recepticle out there too, in addition to the lights. Why waste the time & money for something that will harm your fridge and only barely possibly cover your needs? The fancy lights have startup surges, not like filament incadesents.
Just not worth the effort to do it this way.
--->Paul
/ Lighting question #29
--->Paul
We ALL agree it is not the RIGHT way to do it.
2006 Heil DOT 406 Comp Fuel Tanker (A64194)
2006 Heil DOT 406...
YALE FORKLIFT (A63291)
2016 Ford Explorer SUV (A64557)
2016 Ford Explorer...
Caterpillar 70in Loader Forks and Frame Attachment (A61572)
Caterpillar 70in...
1994 CHEVROLET GMT-400 EXTENDED CAB TRUCK (A65054)
1994 CHEVROLET...
2003 Sterling L7500 S/A Day Cab Truck Tractor (A64556)
2003 Sterling...
