Rotary Cutter Large Area Mowing
/ Large Area Mowing #41
And just who are you calling intelligent!?!?!? :laughing:
"Seemingly" intelligent as I am easily fooled being young and gullible.:laughing:
/ Large Area Mowing #42
Why does every pro flail mower person automatically site the reason to get a flail over a rotary is because a rotary can "sling objects from underneath the mower." If you don't think a flail can throw things your kidding yourself. Most flails have a roller on the back that does a good job at stopping things but they also have about an 8" gap above that to shed clippings that lots of hard objects can come flying out at very high rates of speed. Plus if you think about it, with a flail you've got all those knives spinning vertically in line with tractor operator, if one of them breaks free it has to go somewhere. I've seen used high end Alamo flails beat to he!! just like a well abused rotary. I'm not bashing flails, I simply think they can be just as dangerous as other mowers.
For what it is worth I know you are not bashing
flailmowers.
The properly designed geometry of a flail mowers
hood AND ITS THICKNESS in construction where
the steel is rolled into the desired shape and length
of the formed piece prior to welding the end weldments
and structural tubing to the mowers hood weldment.
This in turn creates the air flow and induces the
aerodynamic forces which create the pressure
gradient that increase the ability of the rotor
and knives to lift and suction the clippings up
and over the rotor back to the ground.
It taks a lot to break a stamped and or a heat
treated grass slicer, and the mowers hood covers
an area greater than 180 degrees in the total
circumference reducing the chance of
an ejected grass slicer or hammer knive.
The other item is the potential trajectory of
a grass slicer knive after it breaks (if it breaks),
as the knive will hit the interior of the hood then
the ground and stick there before it can be
bounced out from under the mower hood.
Most of the time the shackle will break-which it is
designed to do as it wears at greater rate than
the knives stamped mounting hole.
The thirty year old grass slicers I have have very
little if any wear in the mounting slots and we have
never had a knive failure from a stamped mounting hole.
The only time a grass knive or hammer knive moves to
some degree is when either of two things happens,
when the flailmowers rotor is spun up to operating speed
and then back down to a stop or being when the grass or
hammer knive and knive hanger impacts and object and
folds back as it passes over the object and it may contact
an adjacent knive or the knive behind it.
Iif the grass slicers are long in size or a finish mower flail rotor
has a high knive count and or a large diameter rotor like my flaimower
where the knives may bump into each other when the centrifugal forces become less and less with relation to the slowing speed of the flail mowers rotor from the destruction of the drive belts or the disengaging of of the Power Take Off at the end of a mowing session.
The disdvantage of a smaller flail mower rotor is that is has to spin faster have longer knives typically than a flail mower with a larger diameter rotor
which does not have to spin as fast as it takes less centrifugal force to move a knive that is smaller in total length as the mass of the rotor itself is greater and the diameter of the flail mowers rotor is larger.
/ Large Area Mowing #43
Well alright then, as long as your not insulting my stupidity we're good. It took a lot of hard work to get where I am :confused2:
/ Large Area Mowing #44
reminds me of a john wayne comment from the green beret's movie.. :)
/ Large Area Mowing #45
flailmowers.
Wow... A long monotonous read which describes why flails are incredibly maintenance intensive, relatively fragile, and over-complicated compared to a MUCH more efficient, lower cost, less hp demanding rotary that'll do the same job at a faster pace.....
If I were in the business of building and selling flail mowers....I'd pay you handsomely....to quit posting......
/ Large Area Mowing #46
how many old MF's you got now? like 35 thru say.. 165?
/ Large Area Mowing #47
1. '56 Ferguson F40
2. '57 Massey Ferguson 50
3. '71 MF150
4. '74 MF150
5. '74MF175
6. '79MF265
5 and 6 will be re-sold when ready.
4 Fords, 2 newer MF's, 8 Deere's, a Kubota, and maybe an Allis Chalmers 190XT (if seller accepts my offer)
/ Large Area Mowing #48
If anyone would like to see flailmowers at workpPlease visit www.inbrezice.com and enjoy the videos of their 21 foot folding gang flailmowers bringing sunflowers and 10 foot goldenrod down to the sod in one pass.
/ Large Area Mowing #49
I use my Kubota 5040(45pto)to pull 8ft LPtractor3.JPGLP3596.jpg,cut our bottum 4' tall weeds and have mowed my yard with it leaves a really good cut.I will say the wider you go,gonna have to really watch for the mower deck digging in. I do use our 12ft sometimes5040 and ds1440.JPG for shorter stuff around 1' but it will dig in when trying to mow low on un-level ground,found out on my yard first time. I just got a 15ft batwingbatwing2.jpg and have also been using it for light clean up,really can make up some ground. I am going to sell my LP 8ft and looking at adding 2 more remotes and getting a 12ft batwing and if I get into some thick stuff can always scoot over some or just pick up a wing....
Smooth pasture was able to run 5mph with 15ft batwing,if your mowing rough ground might as well go as wide as you can,gotta go slow anyways...
/ Large Area Mowing #50
our county has some 20' schulte rotary mowers.
for stemmy stuff in dry WRA's they pulled em with the same 7610s that normally pull 15' mowers for ROW mowing.. Might want a touch more hp in grass though.. but then.. those are 95 hp tractors only.. 110-130 might be nice in lush grass...
John Deere 5100M (A53317)
John Deere 5100M...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
2016 Textron T/A 15 Ton Dovetail Equipment Trailer (A59230)
2016 Textron T/A...
2022 FORD F-250 STV CREW CAB TRUCK (A59823)
2022 FORD F-250...
Coats 5040A Tire Changer Machine (A59230)
Coats 5040A Tire...
2008 Ford Escape XLS SUV (A59231)
2008 Ford Escape...
