Rake Landscape Rake Wheel Kits
/ Landscape Rake Wheel Kits #1
ksmmoto
Central Lower Michigan
Kubota L3430
I checked at TSC for a wheel kit for my King Kutter 6' Landscape Rake. They are special order and with the shipping and handling came to about $250 at TSC.
I see in Northern Tool that a kit for the Howse brand is $155. Would this fit the KK or has someone found a cheaper source for the KK wheel kit?
Thanks,
ksmmoto
/ Landscape Rake Wheel Kits #2
Is making your own an option? If you own or have access to a welder, you could probably make a better set for less. I'll post a picture of mine if your interested. I know there have been other homemade ones posted in the past.
/ Landscape Rake Wheel Kits #3
</font><font color="blue" class="small">( Is making your own an option? If you own or have access to a welder, you could probably make a better set for less. I'll post a picture of mine if your interested. I know there have been other homemade ones posted in the past. )</font>
Even if you can't weld I think the "drill and bolt together" approach could work very well.
I remember seeing someone's wheel kit here recently, built from a pair of swing away trailer jacks, the sort with jockey wheels. I think that was something he had designed/invented for all his dirt moving tools; rake, grader blade, box scraper, etc and I think he used 2 inch square tube trailer receiver steel as his adapter standard. Hitch pins on/off move them to another implement,
/ Landscape Rake Wheel Kits #4
I picked up a set on ebay last year for $35.00. I ended up having to put tubes in the tires for $10.00 more dollars. Also as mentioned you could fab up a set. Shouldn't be too hard.
Rodger
2021 Takeuchi TL6R High Flow Compact Track Loader Skid Steer (A61572)
2021 Takeuchi TL6R...
2021 Ford F-150 4x4 Crew Cab Pickup Truck (A61573)
2021 Ford F-150...
(2) UNUSED 14X17.5 TIRES W/ 8 LUG RIMS (A64280)
(2) UNUSED 14X17.5...
2006 Mack Granite CV713 Dumping Flatbed (A62679)
2006 Mack Granite...
2012 Ford Escape SUV (A61574)
2012 Ford Escape...
2007 Load - Max Loadmaster Gooseneck Trailer (A66285)
2007 Load - Max...
