Rake Landscape Rake Wheel Kits
/ Landscape Rake Wheel Kits #1
ksmmoto
Central Lower Michigan
Kubota L3430
I checked at TSC for a wheel kit for my King Kutter 6' Landscape Rake. They are special order and with the shipping and handling came to about $250 at TSC.
I see in Northern Tool that a kit for the Howse brand is $155. Would this fit the KK or has someone found a cheaper source for the KK wheel kit?
Thanks,
ksmmoto
/ Landscape Rake Wheel Kits #2
Is making your own an option? If you own or have access to a welder, you could probably make a better set for less. I'll post a picture of mine if your interested. I know there have been other homemade ones posted in the past.
/ Landscape Rake Wheel Kits #3
</font><font color="blue" class="small">( Is making your own an option? If you own or have access to a welder, you could probably make a better set for less. I'll post a picture of mine if your interested. I know there have been other homemade ones posted in the past. )</font>
Even if you can't weld I think the "drill and bolt together" approach could work very well.
I remember seeing someone's wheel kit here recently, built from a pair of swing away trailer jacks, the sort with jockey wheels. I think that was something he had designed/invented for all his dirt moving tools; rake, grader blade, box scraper, etc and I think he used 2 inch square tube trailer receiver steel as his adapter standard. Hitch pins on/off move them to another implement,
/ Landscape Rake Wheel Kits #4
I picked up a set on ebay last year for $35.00. I ended up having to put tubes in the tires for $10.00 more dollars. Also as mentioned you could fab up a set. Shouldn't be too hard.
Rodger
2006 Freightliner Auger Truck (A63688)
2006 Freightliner...
2016 CATERPILLAR 308E2 CR EXCAVATOR (A64279)
2016 CATERPILLAR...
2013 Ford F-350 4x4 Crew Cab Knapheide Service Truck (A61573)
2013 Ford F-350...
2019 Nissan Sentra Sedan (A61574)
2019 Nissan Sentra...
2019 Ford Explorer AWD SUV (A61574)
2019 Ford Explorer...
2018 Freightliner M2 106 AWD Altec AA55 56ft. Insulated Material Handling Bucket Truck (A60460)
2018 Freightliner...
