Land Leveler Completed
/ Land Leveler Completed #21
Very good! I agree that the angled blades cut aka slice material instead of bluntly running into it. Like an exacto blade: Hold it vertical & try to cut & it just tears the paper & bunches it up, but the further you angle the exacto downward, the smoother it cuts.
I've thought about the possibility of adding a gauge wheel to my grading scraper. I know it would be longer, which is the idea for a better grade result, but it could removable, too, for times when just the scraper itself is needed :thumbsup:
/ Land Leveler Completed #22
Very nicely done :thumbsup: Your adjustable blades look great.
gg
/ Land Leveler Completed #23
The main thing it will need is skids.
Two other differences are that the land planes have a 2nd blade parallel to the first, & the blades are slightly angled to direct material toward the left for road crowning. I think you could make a pretty darn good land plane just by adding side skids, though.
When I said converting I meant cutting it apart to use parts from.I could use the hitch. The rippers and mine has 2 cutting edges. I would just meed the side plates with skids.
Bill
/ Land Leveler Completed #24
Great job building your land plane (or whatever we're calling them :laughing:) I will use your photos and description as reference when I build mine. :thumbsup:
/ Land Leveler Completed #25
Them dang quality inspectors... showin up in shorts and flip flops and expecting the whole shop to just shut down when they arrive :D
/ Land Leveler Completed #26
Because this implement gets used as a land plane and as a grader blade I think that we ought to call them LPGBs. (Land Plane Grader Blade) ;)
/ Land Leveler Completed #27
And for additional words, Land Pride calls it a Grading Scraper :)
LPGSB (Land Plane Grading Scraper Blade)?
/ Land Leveler Completed #28
Good work and thanks for sharing the insight into what makes it work, especially the angled blades, I had never thought of that.
Ken
/ Land Leveler Completed #29
However, that's if you buy it, but if you make it yourself, it's home built, so it's actually called a HBLPGSB (Home Built Land Plane Grading Scraper Blade)
/ Land Leveler Completed #30
Nice job. :thumbsup:
2024 CATERPILLAR 930 AG HANDLER WHEEL LOADER (A52709)
2024 CATERPILLAR...
2019 LOAD TRAIL 35+5 GOOSENECK TRAILER (A58214)
2019 LOAD TRAIL...
2017 Ford Explorer AWD SUV (A59231)
2017 Ford Explorer...
2016 MACK CXU613 MID-ROOF SLEEPER (A58214)
2016 MACK CXU613...
Case-IH 370 Steiger (A57148)
Case-IH 370...
2008 Ford F-250 Lariat 4X4 - 303,424 miles - 6.4L Powerstroke -Automatic (A61307)
2008 Ford F-250...
