Land Leveler Completed
/ Land Leveler Completed #21
Very good! I agree that the angled blades cut aka slice material instead of bluntly running into it. Like an exacto blade: Hold it vertical & try to cut & it just tears the paper & bunches it up, but the further you angle the exacto downward, the smoother it cuts.
I've thought about the possibility of adding a gauge wheel to my grading scraper. I know it would be longer, which is the idea for a better grade result, but it could removable, too, for times when just the scraper itself is needed :thumbsup:
/ Land Leveler Completed #22
Very nicely done :thumbsup: Your adjustable blades look great.
gg
/ Land Leveler Completed #23
The main thing it will need is skids.
Two other differences are that the land planes have a 2nd blade parallel to the first, & the blades are slightly angled to direct material toward the left for road crowning. I think you could make a pretty darn good land plane just by adding side skids, though.
When I said converting I meant cutting it apart to use parts from.I could use the hitch. The rippers and mine has 2 cutting edges. I would just meed the side plates with skids.
Bill
/ Land Leveler Completed #24
Great job building your land plane (or whatever we're calling them :laughing:) I will use your photos and description as reference when I build mine. :thumbsup:
/ Land Leveler Completed #25
Them dang quality inspectors... showin up in shorts and flip flops and expecting the whole shop to just shut down when they arrive :D
/ Land Leveler Completed #26
Because this implement gets used as a land plane and as a grader blade I think that we ought to call them LPGBs. (Land Plane Grader Blade) ;)
/ Land Leveler Completed #27
And for additional words, Land Pride calls it a Grading Scraper :)
LPGSB (Land Plane Grading Scraper Blade)?
/ Land Leveler Completed #28
Good work and thanks for sharing the insight into what makes it work, especially the angled blades, I had never thought of that.
Ken
/ Land Leveler Completed #29
However, that's if you buy it, but if you make it yourself, it's home built, so it's actually called a HBLPGSB (Home Built Land Plane Grading Scraper Blade)
/ Land Leveler Completed #30
Nice job. :thumbsup:
Lol, he often has to take an afternoon nap and juice breaks, and sometimes upper management just slows down the whole operation!!!
/ Land Leveler Completed #32
Are you still planning to provide a sketch and more details about the build.
Bobby
/ Land Leveler Completed #34
I love to see some large format pics of each main part up fairly close
Great job!
/ Land Leveler Completed #35
I have been looking into buying/building one of these. Can you give an estimated cost and would you consider sharing the design?
100 GALLON L SHAPE FUEL TANK (A62131)
100 GALLON L SHAPE...
UNUSED KJ 20' BI-PARTING GALVANIZED GATE (A62131)
UNUSED KJ 20'...
66'' BUCKET WITH TEETH (A61567)
66'' BUCKET WITH...
UNUSED JCT 84" HYD ROCK GRAPPLE BKT (A62131)
UNUSED JCT 84" HYD...
Kubota SVL 75-2 (A60462)
Kubota SVL 75-2...
2013 John Deere 2623VT Vertical Tillage Tool (A63116)
2013 John Deere...
