Land Leveler Completed
/ Land Leveler Completed #21
Very good! I agree that the angled blades cut aka slice material instead of bluntly running into it. Like an exacto blade: Hold it vertical & try to cut & it just tears the paper & bunches it up, but the further you angle the exacto downward, the smoother it cuts.
I've thought about the possibility of adding a gauge wheel to my grading scraper. I know it would be longer, which is the idea for a better grade result, but it could removable, too, for times when just the scraper itself is needed :thumbsup:
/ Land Leveler Completed #22
Very nicely done :thumbsup: Your adjustable blades look great.
gg
/ Land Leveler Completed #23
The main thing it will need is skids.
Two other differences are that the land planes have a 2nd blade parallel to the first, & the blades are slightly angled to direct material toward the left for road crowning. I think you could make a pretty darn good land plane just by adding side skids, though.
When I said converting I meant cutting it apart to use parts from.I could use the hitch. The rippers and mine has 2 cutting edges. I would just meed the side plates with skids.
Bill
/ Land Leveler Completed #24
Great job building your land plane (or whatever we're calling them :laughing:) I will use your photos and description as reference when I build mine. :thumbsup:
/ Land Leveler Completed #25
Them dang quality inspectors... showin up in shorts and flip flops and expecting the whole shop to just shut down when they arrive :D
/ Land Leveler Completed #26
Because this implement gets used as a land plane and as a grader blade I think that we ought to call them LPGBs. (Land Plane Grader Blade) ;)
/ Land Leveler Completed #27
And for additional words, Land Pride calls it a Grading Scraper :)
LPGSB (Land Plane Grading Scraper Blade)?
/ Land Leveler Completed #28
Good work and thanks for sharing the insight into what makes it work, especially the angled blades, I had never thought of that.
Ken
/ Land Leveler Completed #29
However, that's if you buy it, but if you make it yourself, it's home built, so it's actually called a HBLPGSB (Home Built Land Plane Grading Scraper Blade)
/ Land Leveler Completed #30
Nice job. :thumbsup:
Lol, he often has to take an afternoon nap and juice breaks, and sometimes upper management just slows down the whole operation!!!
/ Land Leveler Completed #32
Are you still planning to provide a sketch and more details about the build.
Bobby
/ Land Leveler Completed #34
I love to see some large format pics of each main part up fairly close
Great job!
/ Land Leveler Completed #35
I have been looking into buying/building one of these. Can you give an estimated cost and would you consider sharing the design?
2022 Bobcat T770 (A64126)
2022 Bobcat T770...
AGT Top Cat Brush Cutter (A64047)
AGT Top Cat Brush...
2018 MACK CXU (PINNACLE) (A65643)
2018 MACK CXU...
Street Sweeper (A60352)
Street Sweeper...
GATOR UTV (A63276)
GATOR UTV (A63276)
4ft Mini Skid Quick Attach Rotary Cutter (A63689)
4ft Mini Skid...
