L5740 Cab -- clearance for rear chains?
/ L5740 Cab -- clearance for rear chains? #1
FatTire
Colorado
Kubota L5740, Unimog 404 w/ snowblower, Deere 620i UTV, MX5100 (sold)
Running R4's, is there enough clearance (couple inches?) at the rear cab post to accommodate a set of tire chains? Or will I need a pair of small wheel spacers?
Nevermind, got some measurements from the dealer who has the tractor, it looks like there should be just enough clearance...
/ L5740 Cab -- clearance for rear chains? #3
Good to know, I can't gt to mine righ now was pretty sure there was enough room. We rarely get snow, so I've never bought chains for any of our tractors.
I might do 2 inch wheel spacers anyway. It looks like with a perfect installation I need 1.25 inch for my chains, minimun. Right now on my MX5100 there are a few partially twisted links that stick out to 1.75", and I don't know if I can guarantee that I won't have some of those occasionally. That's cutting it close if there is 2" clearance.
/ L5740 Cab -- clearance for rear chains? #5
You can buy longer studs from Kubota for spacers. My custom wheel weights add an extra inch at the flange, and an inch extra is the minimum I suggest with chains.
I didn't know that, thanks. I might like that approach better than going out 2 or 3 inches with an extra set of studs.
/ L5740 Cab -- clearance for rear chains? #7
Are you talking inside clearance or top side? Either way I think there's been an ongoing secret tractor fender clearance conspiracy for past two decades. Haven't these tractor manufacturers ever heard of tire chains for ice&snow, or they trying to start a market for wheel spacers and/or aftermarket for Extra Clearance Fenders for tractors.
/ L5740 Cab -- clearance for rear chains? #8
Local dealer was Clueless on the studs. I bought them for a dealer in Vermont.
That seems to happen a lot. Save their name, you'll probably need it again.
/ L5740 Cab -- clearance for rear chains? #10
/ L5740 Cab -- clearance for rear chains? #11
I have Duo links on my 5240 HSTC w/R4's. Fits fine, bith F&R, but note that I also have the wheels set tot he widest position that they can be, stock. No additional spacers, just flipping around the hub disc and wheels to get the right orientation.
Can you tell me with that orientation how much clearance you are getting between the tire and the rear cab post? Or whatever is the closest point of potential interference.
Talking about clearance to the inside. Over the top there is about 7 inches of clearance. Yes, I cannot imagine why they wouldn't provide a few inches clearance on all versions. We are not talking about a Toyota Prius here. (Nothing against Prius, but that's as opposite from a work machine as I could quickly think of.)
/ L5740 Cab -- clearance for rear chains? #14
I can grab a couple pics and measurements tomorrow to show you the set up. Assuming I remember... If not, poke me again...
/ L5740 Cab -- clearance for rear chains? #16
Here is how mine are set.
Ok, I see, this must be the same setup as mentioned by dstig1 above. How much clearance do you have with that set up?
/ L5740 Cab -- clearance for rear chains? #18
I really don't know exactly and can't get down to it to measure, but it looks like plenty. I mucked a pond out with it and loaded the tires up pretty good with mud and they never rubbed. Here is a picture I just found.
Looks good! So that means I won't have to buy anything or make anything, good news.
/ L5740 Cab -- clearance for rear chains? #20
Is it possible to reposition the rim on the disk to gain more clearance? I'm looking at buying a new to me tractor and the one I looked at today had 17.4L-24 R4's with two piece rims. I was discouraged by the lack of tire chain clearance. This was a smaller L3x40 tractor, but I'm certain your rims are the same style.
The wheels look like the rim can be disassembled from the disk (hub) and repositioned to alter back spacing. The sales person thought it might be possible but never had anyone request it before. They commented they have done this on AG wheels before, but uncertain about the R4's.
Called another dealer and they didn't know either. They suggested using spacers, until they verified Kubota doesn't offer them for the Grand L tractors only the basic L's and B's.
Has anyone tried repositioning the rim/wheel disk?
It would be really nice if this is possible and a zero $ solution if it is possible.
After posting the above, I reread the entire string of responses and noticed post #11 address this. Can you provide details how this is done.
2018 Chevrolet Trax SUV (A59231)
2018 Chevrolet...
4021 (A59228)
4021 (A59228)
2011 VOLVO A40F OFF ROAD DUMP TRUCK (A60429)
2011 VOLVO A40F...
CASE INTERNATIONAL 5140 TRACTOR (A52707)
CASE INTERNATIONAL...
V.E. ENTERPRISES 500 BBL FRAC TANK (A58214)
V.E. ENTERPRISES...
GE WASHER & DRYER (A60432)
GE WASHER & DRYER...
