L5740 Cab -- clearance for rear chains?
   / L5740 Cab -- clearance for rear chains? #1
FatTire
Colorado
Kubota L5740, Unimog 404 w/ snowblower, Deere 620i UTV, MX5100 (sold)
Running R4's, is there enough clearance (couple inches?) at the rear cab post to accommodate a set of tire chains? Or will I need a pair of small wheel spacers?
Nevermind, got some measurements from the dealer who has the tractor, it looks like there should be just enough clearance...
   / L5740 Cab -- clearance for rear chains? #3
Good to know, I can't gt to mine righ now was pretty sure there was enough room. We rarely get snow, so I've never bought chains for any of our tractors.
I might do 2 inch wheel spacers anyway. It looks like with a perfect installation I need 1.25 inch for my chains, minimun. Right now on my MX5100 there are a few partially twisted links that stick out to 1.75", and I don't know if I can guarantee that I won't have some of those occasionally. That's cutting it close if there is 2" clearance.
   / L5740 Cab -- clearance for rear chains? #5
You can buy longer studs from Kubota for spacers. My custom wheel weights add an extra inch at the flange, and an inch extra is the minimum I suggest with chains.
I didn't know that, thanks. I might like that approach better than going out 2 or 3 inches with an extra set of studs.
   / L5740 Cab -- clearance for rear chains? #7
Are you talking inside clearance or top side? Either way I think there's been an ongoing secret tractor fender clearance conspiracy for past two decades. Haven't these tractor manufacturers ever heard of tire chains for ice&snow, or they trying to start a market for wheel spacers and/or aftermarket for Extra Clearance Fenders for tractors.
   / L5740 Cab -- clearance for rear chains? #8
Local dealer was Clueless on the studs. I bought them for a dealer in Vermont.
That seems to happen a lot. Save their name, you'll probably need it again.
   / L5740 Cab -- clearance for rear chains? #10
Honda EM3500SX Portable Gasoline Generator (A59228)
Honda EM3500SX...
2011 John Deere 7330 (A59814)
2011 John Deere...
Honda EM3500S Portable Gasoline Generator (A59228)
Honda EM3500S...
2022 Schulte SMR-800 Multi Rake Landscape Windrower (A56438)
2022 Schulte...
207273 (A52708)
207273 (A52708)
Butler MFG Water Tanker (A56438)
Butler MFG Water...
