L39s are arriving!
/ L39s are arriving! #21
How big is that tractor, HP wise. I have heard repeatedly from a fellow here mention that a .05 cent oring can cause you to rebuild a HST. That conflicts with what my local dealer says.
PS, try your tractor at about 1800 to 2000 RPM and tell me how you like that range. I find the engine does very well in that ballpark. For mowing, I'm at about 2300 RPM, a noticeable difference in sound level.
/ L39s are arriving! #22
The MF 1030 4WD Hydro has 3-cylinder and is 30HP, it is basically a minimalistic subcompact.
/ L39s are arriving! #23
Regarding HST and GST on either L39 or L48, I would have to say either tranny is suitable for certain needs. Nothing is going to be everything to everyone. I love my L48 and the HST, and yes, Rat makes a point about it being slow. It is slow because it is 2X the machine a L3830 is and is way to heavy to be charging around on. An L3830 will not do what an L48 will do, nor should it be expected to. Put a frame, huge loader and hoe, and many other heavy duty items on an L3830 and I bet it would not be as peppy as you describe. The TLB machines are not CUTs and should not be compared as such. An L39 or 48 is in a different class than the Grand Ls and both have short coming when making comparisons. I had a L2350 GST after owning Fords forever and I thought the GST was the best thing since getting laid. I would love my L48 to be GST in certain circumstances, but HST is what it has and it does what it should do well, move lots of dirt and dig.
How are the straight arms on the L39 anyone?
I feel my L48 can be shaken around by my hoe (BT1100), how is the L39?? I am working in snow though.
/ L39s are arriving! #24
You are quite correct. The L48 is a dirt machine. It did a incredible job with my boxscraper that is now on my L3830. It also handled the Harley landscape rake with ease. Medium gear turned my boxscraper into a bull dozer when used in reverse. There I notice the difference in the physical size and ability of the L48 and other machines I have operated. I would find it was the one time that I needed low on the L48. It is perhaps the most glaring difference between the L48 and the L3830 in terms of power. Did you know the L3830 engine is basically the L48 engine with one less cylinder. Same bore and stroke. The loader on the L48 was also quite strong but its biggest advantage was how high it could lift/dump a load. I miss that.
Really, you hardly ever use the clutch...Maybe it's just that I am preconditioned to use a clutch when shifting gears from forward to reverse. Moving from one gear to the next while going in a particular direction was slick. There is a slight delay and it picks up perfectly. I did like that, but I'll get used to the rest of it. I'm certainly glad to hear you like the transmission and I'm looking forward to learning more about it.
/ L39s are arriving! #29
Jim, I'm sure you will find GST to be a snap. I still use a L4850, a 5 cylinder tractor from Kubota. It uses hydraulic shuttle shift and I find once you get it down, you go clutchless for most of the things you do. There is still that slight clutch slip that you need to do when doing loader work in tough material.
</font><font color="blue" class="small">( The TLB machines are not CUTs and should not be compared as such.)</font>
Although, it is a "COMPACT" Utility Tractor. It sort of crosses the line a bit, kind of like the "missing link" they've been searching for for so many years. /forums/images/graemlins/smile.gif It's a neat mix of TLB and CUT. I like it.
/ L39s are arriving! #31
What I miss most about the GST is the ability to match the preferred ground speed with the right umphh and torque, where as with the HST you seem to float above or below it most of the time. I like the analogy about the sliding down the snow bank with the clutch in…….that I don’t miss (although I do drive all of my other tractors regularly as a reminder and to keep them running). GST allows you to choose the optimum speed, with some mechanical manipulation.
Tried to put my hoe on after taking my 3PT plow off…..couldn’t get the quick attach couplers together????!!!!!! Friend said put the nipple of the male ends against metal to relieve the pressure. Any suggestions?
/ L39s are arriving! #33
With the tractor off, take a wrench and open the fitting at the quick coupler a little to relieve the pressure. Keep your hands away from the imediate area as best you can as hydraulic fluid under pressure can pierce your skin and all sorts of badness begins...
Curtis,
My buddy who owns a JD110 has similar problems sometimes, and I suppose I'll have the same with this L39. He makes sure all tension is full relieved from the loader arms and bucket (moves the loader stick in every possible direction a few times), then if he needs to, I believe he said he presses the male end on a piece of steel to further relieve hydraulic tension, as others suggested.
The stabilizers were in ice and snow, but the hoe could pull the machine around at will. I'm sure it'll improve when they bite into soft earth or grab on the rubber street pads.
/ L39s are arriving! #36
Jim , a little settlling into the ground and all those relieved pressures come back. A few hundred pounds eqautes into unmateable couplings. I usually try to pop the end of the male fitting to get things back to normal. Don't laugh!
/ L39s are arriving! #37
If you were idling while disconnecting or connecting., you will not be able to hook lines together. I found on the 48 to shut it down, release all hydraulic pressures including front loader, and also leaving lever to backhoe. (don"t know if 39 is same) 48 has lever for backhoe or 3pt hitch.
/ L39s are arriving! #38
Thanks everyone, I finally did relieve the pressure on one of the lines. Don’t remember which one (blue cap) but it was the only one that would release. No problems, popped right away….it was just the one line I didn’t try. It was just the L48s way of telling me the day is over after such a long day. I fuel the thing every day!!!! 26$+ each time. I think Rats comment about movement after disconnecting could be it…I never had that problem before. Really missing a drink holder, the only thing (besides a higher medium HST range) missing is the drink holder. I will actually be installing a small cooler.
Great Plains Ultra Till 3030 (A63688)
Great Plains Ultra...
(5) 2" X 20' STEEL PIPE (A64281)
(5) 2" X 20' STEEL...
Caterpillar 214-224 Wheel Type Excavator Service and Parts Manuals (A63117)
Caterpillar...
UNUSED WOLVERINE LAND LEVELER (A64281)
UNUSED WOLVERINE...
2018 22ft. Tycorp Vector Belt VB-16H (A60352)
2018 22ft. Tycorp...
2018 VOLVO SD115B PADFOOT ROLLER (A64279)
2018 VOLVO SD115B...
