L3800 doing work
   / L3800 doing work #1
elmer4413
Ohio
Kubota L3800
Started working on my food plots yesterday. This tractor is the perfect setup for small food plots while navigating around trees. This was my first time using a tiller behind a tractor and I was very impressed how deep it actually digs.
   / L3800 doing work #2
Wish I could do food plots that easy. My ground is just too rocky.
   / L3800 doing work #3
Take the loader off and it is even more maneuverable.
   / L3800 doing work #4
Looks like you have pretty good dirt... we have rocks...:eek:
   / L3800 doing work #7
Yep, my FEL usually stays off. It's like a different tractor!
I am quite the opposite. I usually leave mine on cause I am usually blading or doing dirtwork, or cutting firewood. All things that the loader comes in quite handy. I even leave it on when bushhogging. Partly due to the ~1100# cutter I use.
But I DO take it off when tilling. Cause when the tiller is in the ground, there aint much weight on the front end, and with the loader it cuts quite deep ruts and compacts the soil alot. Without the loader, the fronts dont cut in much at all.
   / L3800 doing work #8
What's your tiller width .
Sent from my iPhone 5 using TractorByNet
   / L3800 doing work #9
Your making it look way to easy..nice setup.
Couple more months even before thinking about turning dirt for us. :(
   / L3800 doing work #10
Makes sense. My FEL stays on most of the fall winter with firewood, logging & some dirt work. But most of the hours I rack up are bush hoggin & I don't mow with the FEL on! Have no tiller here, but would do as you do there.
Forklift (A59228)
Forklift (A59228)
New/Unused Quick Attach Pallet Forks (A57453)
New/Unused Quick...
2004 Freightliner FL70 Garbage Truck, VIN # 1FVABTCS64HM47795 (A57453)
2004 Freightliner...
2017 Snorkel S4732 Scissor Lift (A57453)
2017 Snorkel S4732...
Honda 24hp Brush Truck Pump (A57454)
Honda 24hp Brush...
Red Stone Fan Forces Quartz Heater (A57453)
Red Stone Fan...
