L3200 replacement tool box
   / L3200 replacement tool box #1
Garandman
Elite Member
Mount Sunapee NH / Dorchester, MA
Kubota L3200 HST
The plastic hinge broke and then today I lost the lid. I'd like to get something a little bigger. I like Pelican cases but they are probably too deep.
Suggestions?
   / L3200 replacement tool box #2
My L3400 came without a toolbox, and I looked around before deciding, to once more (I had used the first one on a B8200 some years ago), install a Craftsman $10 plastic toolbox- the size seems perfect, it's waterproof, and has a sturdy hinge/latch arrangement. It is actually a bit bigger than the factory steel toolbox that was on my L3130. I will follow up with a photo tomorrow.
Okay- here're a couple photos- the box fits quite nicely between the fenders. I think it would do the same with a L3200.
   / L3200 replacement tool box #3
   / L3200 replacement tool box #4
I got a "Homer box" from Home Depot. Just a generic tool box twice the size of the OEM one. Happens to be Kubota orange. Drilled 2 holes in the bottom & mounted. The bigger box barely hits the back of the seat & wiggles a bit due to the extra weight of all the crap I have in it. It works better than OEM but not great.
   / L3200 replacement tool box #5
I bought a Homer Box like Fallon to replace that little waste of a box that came on my L3200 but when I went to replace it I decided that the Homer Box was too large. Instead, I used an old Craftsman tool box that I already had and it fit much better. I then used the Homer Box to replace the Craftsman box and now have more room for both applications.
   / L3200 replacement tool box #7
I took a different approach. There wasn't any place that really appealed to me for mounting a box on the L3200. Valuable spaces were already taken up by the cab, externally mounted rear wiper and control box for the rear blower. I don't need a large tool box, just a few wrenches, Channellocks, pins, shear bolts, etc. Everything I want fits into a soft tool bag that stows under the left side of the seat. When I built the cab, I used a cow mat to block off the area under and behind the seat and it created a stiff floor there.
It stays dry, no brackets to build, nothing to vibrate loose over time.
EDIT TO ADD: Just noticed the wood showing in the pic. That's not part of the cab fab [grin]. That's the "Unclogger" for the snow blower made from an old baseball bat that I ran through the saw at work to make it about an inch thick. The end is now chisel-shaped.
What about milsurp or aftermarket ammo cans?
This plastic one is
Outside dimensions: 8.75" (L) x 15.5" (W) x 9" (H) Inside dimensions: 7.5" (L) x 13" (W) x 7.25" (H)
O-Ring seal
Designed for stacking
Rugged polypropylene plastic
Durable and moisture resistant; Made in USA
A 40mm can is 18 wide by 6" deep by 10" high, also about $20.
New sty'e 40 cal box is 12 in. x 7 in. x 8½ h.
   / L3200 replacement tool box #9
I just cut a piece of piano hinge and pop riveted it in place.
Works fine, fast simple fix.
It is still going strong. but still still small and still too dirty :)
Measured the stock box. It's roughly 14" wide, 5" front-to-back, and about 3" high without the lid. There is only about 1" of clearance behind it, but up to 3" in front of it.
Think I'm just going to mount a 50 cal ammo can.
   / L3200 replacement tool box #12
The only thing I would consider is whether the mounting strut can take the leverage of anything taller or heavier than the stock toolbox. It's fairly sturdy with the stock box, but it's still a pretty small piece of steel and will flex.
   / L3200 replacement tool box #13
My Homer box makes it twist a bit. Much bigger or heavier would pose problems I bet.
I tried one of the plastic cans and the bottom isn't strong enough and it's a little too narrow.
I'm going to use a USGI .50 Cal can painted orange. Kubota Orange seems to be the same as Ariens Orange, which means it's the same as Chevy Engine Orange, which is $5 a can.
2025 CFG Industrial MX12RX Mini Excavator (A59228)
2025 CFG...
2021 Kubota RTV-X1140 4x4 Diesel Utility Cart (A59228)
2021 Kubota...
2022 CATERPILLAR 303.5CR EXCAVATOR (A60429)
2022 CATERPILLAR...
2019 Ford F-150 4x4 Ext. Cab Pickup Truck (A59230)
2019 Ford F-150...
2001 FORD F-750 SUPER DUTY (INOPERABLE) (A58214)
2001 FORD F-750...
UNUSED RAYTREE RMRB72-72" HYD POWER RAKE BUCKET (A60432)
UNUSED RAYTREE...
