L3200 replacement tool box
/ L3200 replacement tool box #1
Garandman
Elite Member
Mount Sunapee NH / Dorchester, MA
Kubota L3200 HST
The plastic hinge broke and then today I lost the lid. I'd like to get something a little bigger. I like Pelican cases but they are probably too deep.
Suggestions?
/ L3200 replacement tool box #2
My L3400 came without a toolbox, and I looked around before deciding, to once more (I had used the first one on a B8200 some years ago), install a Craftsman $10 plastic toolbox- the size seems perfect, it's waterproof, and has a sturdy hinge/latch arrangement. It is actually a bit bigger than the factory steel toolbox that was on my L3130. I will follow up with a photo tomorrow.
Okay- here're a couple photos- the box fits quite nicely between the fenders. I think it would do the same with a L3200.
/ L3200 replacement tool box #3
/ L3200 replacement tool box #4
I got a "Homer box" from Home Depot. Just a generic tool box twice the size of the OEM one. Happens to be Kubota orange. Drilled 2 holes in the bottom & mounted. The bigger box barely hits the back of the seat & wiggles a bit due to the extra weight of all the crap I have in it. It works better than OEM but not great.
/ L3200 replacement tool box #5
I bought a Homer Box like Fallon to replace that little waste of a box that came on my L3200 but when I went to replace it I decided that the Homer Box was too large. Instead, I used an old Craftsman tool box that I already had and it fit much better. I then used the Homer Box to replace the Craftsman box and now have more room for both applications.
/ L3200 replacement tool box #7
I took a different approach. There wasn't any place that really appealed to me for mounting a box on the L3200. Valuable spaces were already taken up by the cab, externally mounted rear wiper and control box for the rear blower. I don't need a large tool box, just a few wrenches, Channellocks, pins, shear bolts, etc. Everything I want fits into a soft tool bag that stows under the left side of the seat. When I built the cab, I used a cow mat to block off the area under and behind the seat and it created a stiff floor there.
It stays dry, no brackets to build, nothing to vibrate loose over time.
EDIT TO ADD: Just noticed the wood showing in the pic. That's not part of the cab fab [grin]. That's the "Unclogger" for the snow blower made from an old baseball bat that I ran through the saw at work to make it about an inch thick. The end is now chisel-shaped.
/ L3200 replacement tool box #9
I just cut a piece of piano hinge and pop riveted it in place.
Works fine, fast simple fix.
It is still going strong. but still still small and still too dirty :)
/ L3200 replacement tool box #12
The only thing I would consider is whether the mounting strut can take the leverage of anything taller or heavier than the stock toolbox. It's fairly sturdy with the stock box, but it's still a pretty small piece of steel and will flex.
/ L3200 replacement tool box #13
My Homer box makes it twist a bit. Much bigger or heavier would pose problems I bet.
I tried one of the plastic cans and the bottom isn't strong enough and it's a little too narrow.
I'm going to use a USGI .50 Cal can painted orange. Kubota Orange seems to be the same as Ariens Orange, which means it's the same as Chevy Engine Orange, which is $5 a can.
2025 Unused SDLGC80 60v Electric Golf Cart (A64194)
2025 Unused...
2011 Peterbilt 6x4 Water Truck w 52,000 GVWR, and 2,000 Gallon Tank (A63689)
2011 Peterbilt 6x4...
2017 Ford F-150 Pickup Truck (A61573)
2017 Ford F-150...
7888SFL (A61567)
7888SFL (A61567)
2016 Ford Transit 250 Cargo Van (A61573)
2016 Ford Transit...
1997 Capacity Spotter Truck (A62679)
1997 Capacity...
