L3200 replacement tool box
/ L3200 replacement tool box #1
Garandman
Elite Member
Mount Sunapee NH / Dorchester, MA
Kubota L3200 HST
The plastic hinge broke and then today I lost the lid. I'd like to get something a little bigger. I like Pelican cases but they are probably too deep.
Suggestions?
/ L3200 replacement tool box #2
My L3400 came without a toolbox, and I looked around before deciding, to once more (I had used the first one on a B8200 some years ago), install a Craftsman $10 plastic toolbox- the size seems perfect, it's waterproof, and has a sturdy hinge/latch arrangement. It is actually a bit bigger than the factory steel toolbox that was on my L3130. I will follow up with a photo tomorrow.
Okay- here're a couple photos- the box fits quite nicely between the fenders. I think it would do the same with a L3200.
/ L3200 replacement tool box #3
/ L3200 replacement tool box #4
I got a "Homer box" from Home Depot. Just a generic tool box twice the size of the OEM one. Happens to be Kubota orange. Drilled 2 holes in the bottom & mounted. The bigger box barely hits the back of the seat & wiggles a bit due to the extra weight of all the crap I have in it. It works better than OEM but not great.
/ L3200 replacement tool box #5
I bought a Homer Box like Fallon to replace that little waste of a box that came on my L3200 but when I went to replace it I decided that the Homer Box was too large. Instead, I used an old Craftsman tool box that I already had and it fit much better. I then used the Homer Box to replace the Craftsman box and now have more room for both applications.
/ L3200 replacement tool box #7
I took a different approach. There wasn't any place that really appealed to me for mounting a box on the L3200. Valuable spaces were already taken up by the cab, externally mounted rear wiper and control box for the rear blower. I don't need a large tool box, just a few wrenches, Channellocks, pins, shear bolts, etc. Everything I want fits into a soft tool bag that stows under the left side of the seat. When I built the cab, I used a cow mat to block off the area under and behind the seat and it created a stiff floor there.
It stays dry, no brackets to build, nothing to vibrate loose over time.
EDIT TO ADD: Just noticed the wood showing in the pic. That's not part of the cab fab [grin]. That's the "Unclogger" for the snow blower made from an old baseball bat that I ran through the saw at work to make it about an inch thick. The end is now chisel-shaped.
/ L3200 replacement tool box #9
I just cut a piece of piano hinge and pop riveted it in place.
Works fine, fast simple fix.
It is still going strong. but still still small and still too dirty :)
/ L3200 replacement tool box #12
The only thing I would consider is whether the mounting strut can take the leverage of anything taller or heavier than the stock toolbox. It's fairly sturdy with the stock box, but it's still a pretty small piece of steel and will flex.
/ L3200 replacement tool box #13
My Homer box makes it twist a bit. Much bigger or heavier would pose problems I bet.
I tried one of the plastic cans and the bottom isn't strong enough and it's a little too narrow.
I'm going to use a USGI .50 Cal can painted orange. Kubota Orange seems to be the same as Ariens Orange, which means it's the same as Chevy Engine Orange, which is $5 a can.
2011 Chevrolet Silverado 1500 Work Truck (A62613)
2011 Chevrolet...
Auger Drill Bit Mini Skid Steer Attachment (A61572)
Auger Drill Bit...
Caterpillar Service Manual Reference Kit for Motor Graders, Wheel Type Tractors, and Equipment (A63117)
Caterpillar...
2013 CATERPILLAR 299D SKID STEER (A60429)
2013 CATERPILLAR...
WoodMaxx MX 9900 with almost no use
WoodMaxx MX 9900...
UNUSED WOLVERINE RCR-12-84W-84" HYD ROCK RAKE (A64281)
UNUSED WOLVERINE...
