Tires L2500 Tires
/ L2500 Tires #1
FlynG
Arkansas
L3710GST FEL R4 6' cutter, misc. other tools
I recently traded in a much larger tractor for this slightly used L2500. It only had 190 hours on it. This is my first Kubota and I am new to this forum, so howdy all!
It came with the turf tires. I am primarily using it to mow pastures so when things get a little wetter I am afraid that I will not like them too much. I do like the floatation qualities and I'm not sure that I want to switch to R1 tires and wheels just yet. Is there an alternative that will fit my current wheels and maintain the proper ratio front to rear for the 4x4?
/ L2500 Tires #2
In most cases (probably all cases), you'll have to change the rims when changing your tire type. According to my L2500 sales brochure, the AG tires are 7-16 (front) and 11.2-24 (rear). This means that the front rim is 16" and the rear rim is 24".
From my experience with B7100s and B2150s, turf tires typically use smaller sized rims than the AG tires do. Your best bet is to find someone with an L2500 with AG tires who would want to swap with you.
That's all the information that I can provide for now. Hope this helps.
/ L2500 Tires #3
I have an L2500 with R1's. I think if I had to do it over again I would go with the R4's. I think that would be a good compromise between ags and turfs. If I ever need more traction I would get chains. You could argue you can do that with turfs also but I just wouldn't be comfortable with turfs in the fields with stumps, branches etc due to the puncture liklihood.
2015 John Deere CX15 (A64126)
2015 John Deere...
2011 Energy Absorption Systems TMA9000 19ft Attenuator Trailer (A61572)
2011 Energy...
WILDKAT 78 ROCK GRAPPLE (A61572)
WILDKAT 78 ROCK...
Lonestar Panel (4) 24ft. Free Standing Panels (A65640)
Lonestar Panel (4)...
Covered Livestock Mineral Feeder (A66408)
Covered Livestock...
Heavy Duty Pipe (A62679)
Heavy Duty Pipe...
