kubota LA352 loader stuck in float position
/ kubota LA352 loader stuck in float position #1
mya
b2410 kubota
kubota la352 loader stuck in float position still after having detent replaced with new , any thoughts or help appreciated
/ kubota LA352 loader stuck in float position #2
Did you replace the parts or the dealer maybe its not back together correct.
A very reputable hydraulic repair shop rebuilt detent
i have seen posts with this same problem but no solutions
/ kubota LA352 loader stuck in float position #5
It might just be hard to pull it out of detent.
its normally harder to pull out but now it will only come out if i hit the bottom of the control lever with a hammer, and dont want to make worse
/ kubota LA352 loader stuck in float position #7
Id try a light spray oil to the parts. I see that its a common problem with that loader valve.
where would you spray oil specifically? everything is well lubricated externally, are you thinking inside the valve ? thanx
/ kubota LA352 loader stuck in float position #9
The cup on the bottom some people drill a little hole to let the water out I'd take that off and spray up in inside that the balls and spring.
/ kubota LA352 loader stuck in float position #10
messicks shows a break down of that valve.
/ kubota LA352 loader stuck in float position #11
If it comes out when you hit it with the hammer I would think its just sticking a bit.
Landhonor Livestock Chute w/ Scale (A66408)
Landhonor...
WESTINGHOUSE PORTABLE ARC WELDER (A64276)
WESTINGHOUSE...
Paladin 12in Bucket w/ Teeth Excavator Attachment (A64194)
Paladin 12in...
2022 EZ-GO ELITE...
WC1105 Wood Chipper (A65579)
WC1105 Wood...
(16) Kinze 3000 Seed Boxes (A65640)
(16) Kinze 3000...
