kubota LA352 loader stuck in float position
/ kubota LA352 loader stuck in float position #1
mya
b2410 kubota
kubota la352 loader stuck in float position still after having detent replaced with new , any thoughts or help appreciated
/ kubota LA352 loader stuck in float position #2
Did you replace the parts or the dealer maybe its not back together correct.
A very reputable hydraulic repair shop rebuilt detent
i have seen posts with this same problem but no solutions
/ kubota LA352 loader stuck in float position #5
It might just be hard to pull it out of detent.
its normally harder to pull out but now it will only come out if i hit the bottom of the control lever with a hammer, and dont want to make worse
/ kubota LA352 loader stuck in float position #7
Id try a light spray oil to the parts. I see that its a common problem with that loader valve.
where would you spray oil specifically? everything is well lubricated externally, are you thinking inside the valve ? thanx
/ kubota LA352 loader stuck in float position #9
The cup on the bottom some people drill a little hole to let the water out I'd take that off and spray up in inside that the balls and spring.
/ kubota LA352 loader stuck in float position #10
messicks shows a break down of that valve.
/ kubota LA352 loader stuck in float position #11
If it comes out when you hit it with the hammer I would think its just sticking a bit.
17601CFL (A61572)
17601CFL (A61572)
2016 PETERBILT 567 TRI AXLE ROLLOFF TRUCK (A65643)
2016 PETERBILT 567...
2019 John Deere M15 Batwing Mower (A66285)
2019 John Deere...
2021 Mercedes-Benz Sprinter 4500 Modified Food Catering Van (A61573)
2021 Mercedes-Benz...
2006 Flori Off Road Dump Truck DF40 (A65579)
2006 Flori Off...
2007 FORD EXPLORER (A65643)
2007 FORD EXPLORER...
