Kubota g1900 Cranks but wont turn over
/ Kubota g1900 Cranks but wont turn over #1
celwood
joppa
kubota g1900
Hello,
Hoping someone can help as my model cant be towed to get it on a trailer.
Unit cranks but wont start.
Replaced battery, replaced rectifier (what the dealership told me to do but didnt solve problem), i get ~ 7 volts at glow plugs when cranking but nothing in on position. Glow plug dash light doesnt work and never has since i have owned it. Its not see voltage in on position. Fuel solenoid doesnt see any voltage in on position. Glow plugs all show about .9 ohms.
Is it the control box? how do you test it to know?
Really appreciate any help that is offered.
/ Kubota g1900 Cranks but wont turn over #2
Will it start with jumper cables? I once bought a new battery for an old SAAB, but the battery wouldn't hold a charge. Spent a very frustrating, bitter cold day in February, on the street in the south end of Bridgeport
checking out alternator, voltage regulator, grounds, terminal connections, etc. Took the battery back and problem solved, but not before learning that a new battery doesn't necessarily mean a good battery.
If it won't jump start, then get a multi-meter and try using it to nrrow down root cause:
http://delcoremy.com/documents/diagnostic-manual.aspx
It doesnt start with a jump either. I used the multimeter to get to the point where i am now.
Thanks for responding and posting that handy manual.
/ Kubota g1900 Cranks but wont turn over #4
Fusible link?
Had to replace one on our G5200H.
If your tractor's the same as ours, it's just a short loop of wire with a quick connect, near the starter.
I was able to buy replacement wire at AutoZone and reuse the connector & get it done on a Sunday afternoon.
what - just do a continuity test on the wire loop to see if bad? I saw it but didnt really understand what it did
Had continuity so, i assume its fine.
/ Kubota g1900 Cranks but wont turn over #7
When mine went bad and I tested it, it seemed okay.
Then I flexed the wire a bit and lost continuity.
I think the wire was randomly making/breaking contact.
Sounds like yours is okay.
I'd start by checking continuity from the battery cable lugs to the starter and ground.
You've got an open circuit somewhere.
I've also had to replace one of those glass bus fuses, located behind the dash; down near the steering column.
Someone here on TBN also had an ignition switch go bad on them.
Do you have the wiring diagram?
You can get that, as a pdf, e-mailed to you from Messick's.
It is tempting to blame that mysterious control box, but every time I start to suspect it something else turns up bad.
/ Kubota g1900 Cranks but wont turn over #8
Why can't this be towed on a trailer?
You could put a sheet of plywood under it, throw a hook on the end of the plywood and pull the plywood on the trailer.:confused2:
Great point. Thanks for responding.
Question- Would a bad ignition or a safety switch allow the engine to crank but not start? Or would either of those things not let it crank at all? How do you tell if ignition is bad?
/ Kubota g1900 Cranks but wont turn over #11
check the fuel solenoid to see if it has power to open and allow fuel to the injection pump....
Remembering.... diesel needs fuel, air, and heat to operate...
/ Kubota g1900 Cranks but wont turn over #12
cranking but no start....some tractors have a safety feature that "disables" the solenoid to the pump,
in this case, yes, a crank but no start would occur.
no crank at all.....yes a defective ignition switch will also give you this along with many other things.
You check your ignition switch with a test light, be careful not to ground out the probe on the test light when doing this.
I did disconnect the connector at the fuel solenoid and there was no voltage when the key was in the on position. However when i connected it back together and turn the key on and then off, i can see the solenoid lever closing when i turn the key off. This leads me to believe its getting power.
/ Kubota g1900 Cranks but wont turn over #14
It still sounds like you have a fuel problem... make sure you have fuel, in the tank and also that it is coming through the filters. Possible plugged fuel filter? Some times I have seen the lines plugged also. And even a cracked fuel line that allowed air in the lines. How cold is it there? Just thinking....
/ Kubota g1900 Cranks but wont turn over #15
Ok more questions, ... when your cranking.... does any smoke come out of the exhaust? If so what color is it? Have you tried starting fluid?
/ Kubota g1900 Cranks but wont turn over #16
Hello,
Check on the bottom of the hydro unit, my G2160 has a small push button for a relief valve that will allow you to move it but will pop out once the engine turns and builds pressure in the pump.
David Kb7uns
I replaced one filter last summer but i think there are two. Intend to check the other tomorrow. I unscrewed one of the "ports" on top of the engine and fuel started seeping out. So i think i have fuel. Will check lines.. Thanks for responding. this is so infuriating.
zero smoke comes out. Althought when it does work, it cranks and then a big black plume comes out when it turns over and then no smoke after that.
David Kb7uns
i had it at the dealer for this problem and they confirmed that this model doesnt have a release for the transmission. Apparently, they changed that shortly after my model was made.
/ Kubota g1900 Cranks but wont turn over #20
Is there a compression release on this tractor if so check under hood and make sure it isn't stuck open
this might be your trouble.
1995 NEWTON CROUCH PULL SPREADER (A57192)
1995 NEWTON CROUCH...
2017 CAT TL1055 (A60462)
2017 CAT TL1055...
2007 JLG E400 AJP TELESCOPIC/SCISSORING MANLIFT (A52707)
2007 JLG E400 AJP...
2015 Ford Escape SUV (A59231)
2015 Ford Escape...
2013 Ford Focus Hatchback (A59231)
2013 Ford Focus...
2020 INTERNATIONAL LT625 SLEEPER TRUCK (A59905)
2020 INTERNATIONAL...
