Kubota g1900 Cranks but wont turn over
   / Kubota g1900 Cranks but wont turn over #11
check the fuel solenoid to see if it has power to open and allow fuel to the injection pump....
Remembering.... diesel needs fuel, air, and heat to operate...
   / Kubota g1900 Cranks but wont turn over #12
Question- Would a bad ignition or a safety switch allow the engine to crank but not start? Or would either of those things not let it crank at all? How do you tell if ignition is bad?
cranking but no start....some tractors have a safety feature that "disables" the solenoid to the pump,
in this case, yes, a crank but no start would occur.
no crank at all.....yes a defective ignition switch will also give you this along with many other things.
You check your ignition switch with a test light, be careful not to ground out the probe on the test light when doing this.
I did disconnect the connector at the fuel solenoid and there was no voltage when the key was in the on position. However when i connected it back together and turn the key on and then off, i can see the solenoid lever closing when i turn the key off. This leads me to believe its getting power.
   / Kubota g1900 Cranks but wont turn over #14
It still sounds like you have a fuel problem... make sure you have fuel, in the tank and also that it is coming through the filters. Possible plugged fuel filter? Some times I have seen the lines plugged also. And even a cracked fuel line that allowed air in the lines. How cold is it there? Just thinking....
   / Kubota g1900 Cranks but wont turn over #15
Ok more questions, ... when your cranking.... does any smoke come out of the exhaust? If so what color is it? Have you tried starting fluid?
   / Kubota g1900 Cranks but wont turn over #16
Hello,
Hoping someone can help as my model cant be towed to get it on a trailer.
Check on the bottom of the hydro unit, my G2160 has a small push button for a relief valve that will allow you to move it but will pop out once the engine turns and builds pressure in the pump.
David Kb7uns
I replaced one filter last summer but i think there are two. Intend to check the other tomorrow. I unscrewed one of the "ports" on top of the engine and fuel started seeping out. So i think i have fuel. Will check lines.. Thanks for responding. this is so infuriating.
zero smoke comes out. Althought when it does work, it cranks and then a big black plume comes out when it turns over and then no smoke after that.
David Kb7uns
i had it at the dealer for this problem and they confirmed that this model doesnt have a release for the transmission. Apparently, they changed that shortly after my model was made.
   / Kubota g1900 Cranks but wont turn over #20
Is there a compression release on this tractor if so check under hood and make sure it isn't stuck open
this might be your trouble.
1987 FORD F-700 FUEL TRANSPORT TRUCK (A58214)
1987 FORD F-700...
Case 930 Tractor (A59814)
Case 930 Tractor...
2009 Peterbilt 335 Cab and Chassis Truck (A55852)
2009 Peterbilt 335...
DRILL CABINET SKID (A58214)
DRILL CABINET SKID...
2004 TAKEUCHI TL140 SKID STEER (A60429)
2004 TAKEUCHI...
2018 Kubota U17 (A53317)
2018 Kubota U17...
