Kubota catastrophic engine failures
/ Kubota catastrophic engine failures #21
My 2019 M5-111 (tier 4) last month had catastrophic engine failure, 1,200 hours, from the diesel high pressure fuel pump. I only use gas station diesel in 5 gallon containers used only for diesel. Cost estimated $17,000. I wonder how many other Kubotas are having this issue. KTAC, Kubota insurance is not covering the claim.
I will start collecting contact info from other Kubota owners to see if this is a systemic problem of filters not filtering and maybe hold Kubota accountable. Send your contact info to me at Landruma@aol.com if interested.
landruma,
Here is link to all Kubota warranties.
/ Kubota catastrophic engine failures #22
Use Mr Funnel to fuel the tractor.
Good idea if you fill from a can. I have seen some real junk come of cans, especially steel ones.
Theoretically nothing should get through the tractor filters so it might be good to only use Kubota filters and keep the receipt.
/ Kubota catastrophic engine failures #23
Had the Ram mechanic tell me similar for my Ram.
Use only Mopar filters. If the filter fails and does damage, Mopar is on the hook.
If using aftermarket filters, the filter company will only give you a new filter.
/ Kubota catastrophic engine failures #24
landruma,
was the tractor purchased new, ie with full warranty ?
or was it purchased used, and there was no warranty transfer ?
the length of warranty appears to vary, depending on part
all the best in getting this sorted
/ Kubota catastrophic engine failures #25
RAM trucks with Cummins power have switched back to CP 3 pumps, If it is only a "fuel" problem then why is it not killing even older CP 3 pumps in large numbers?
Sure sounds like the CP 4 is not as tough, and from reports it sends metal everywhere when it begins to fail Not something that is reported widely with a CP 3.
Maybe the lawsuits will sort it all out.
/ Kubota catastrophic engine failures #26
OH Not where I was Going. But do see your point.
All the world needs are more lawsuits.
CP 3 is proven with a good record. I guess at about 200 K miles I should expect to have to replace the injectors as consumable wear parts though.
I find it interesting that the CP3 was always able to provide the needed pressure and volume for even the newest most powerful Cummins equipped RAM the whole time.
/ Kubota catastrophic engine failures #27
Not sure it’s related but diesel powered pickup trucks in the US equiped with the Bosch CP4 high pressure fuel pump have seen a lot of failures. Failure of the pump send pieces downstream sometimes resulting in $10k or more for repairs.
Failure of the pump has been attributed to lower lubricity in US diesel fuel compared to diesel fuel in Europe. Failures have generally occurred at around 100,000 miles. There are several class action lawsuits against Ford, GM, FCA, and Bosch.
VW diesels past 2009 with Bosch pumps were saved by "dieselgate", the massive recall of virtually all the vehicles sold before 2015.
From about 2010 on VW fuel pumps were failing, Bosch even published a paper mentioning the lower lubricity as the problem.
VW no longer offers a diesel car in North America. I miss my 42 MPG 2009 Jetta.
/ Kubota catastrophic engine failures #28
The lubricity problem is what I try to avoid striking by adding 6 ounces of Marvel Mystery Oil to each five gallons of diesel.
/ Kubota catastrophic engine failures #29
How do you have a $17K estimate if the dealer hasn’t opened it up yet?
Because that's what they estimated it would cost. They told him 17k and then he told you 17k. Just following the trail
/ Kubota catastrophic engine failures #30
I took one of them vw engines and rebuilt it. Still going. Wish I'd known. But that would mean I'd have to live near people. So I guess it's okay.
/ Kubota catastrophic engine failures #31
Another water in the fuel tragedy. Water and high pressure common rail diesels do not mix. Filter your fuel and make sure it has a water block in the filter media.
/ Kubota catastrophic engine failures #32
Kubota insurance should cover the cost if the warrantee doesn't. Less $250. I've had 3 claims on my 2017 M5-111. A DEF header replacement. Front body repair from tree limbs passing by my grapple. And a front windshield replacement. The Kubota insurance people are very nice. And they will ask what dealer you prefer.
Call them. 1-800-348-5802 option 1
/ Kubota catastrophic engine failures #33
About the failure - "fuel pump not drawing fuel". The high pressure fuel pump is pressure fed by an electric feed pump. I believe the high pressure pump is a Denso. It is variable displacement holding required rail pressure based on a signal from the ECU. Very unusual failure mode. I have had 5 Tier 4 Kubotas including a M5-111 with no problem but I try keeping my fuel as water free as I can - water block filter before fuel goes into the tank, then the tractor water separators. My M7 does have a water in fuel indicator but all they are is a switch saying that the water level at the bottom of the water separator has hit a certain level. My water separators have shut the engine down by blocking fuel to the high pressure pump before coming close to the switch. The bowls at least 2 of mine are clear plastic and I can see the water level, much more effective than a switch. My M7 actually has notified me of a blocked water separator with the ECU warning "Low Fuel Rail Pressure - See Dealer". That's the indicator the high pressure pump cannot get enough fuel to meet the rail demand. Time to change water separator. To prevent damage, this is a shut down situation. Run it longer and the FIP is running without its lube - fuel.
/ Kubota catastrophic engine failures #35
I'm pretty sure the dealers technician is parroting what Kubota told him Kubota tech are al\lw3ays under continuing education as the products evolve.
/ Kubota catastrophic engine failures #37
Deleted not specific enough to Kubota diesel CRS
/ Kubota catastrophic engine failures #38
I'm guessing you won't find anyone with the same failure.
There was a guy with the same failure last week. Was a kubota.... something about water in the fuel.
Here's the link
/ Kubota catastrophic engine failures #39
I know that there were issues with Volkswagen high pressure fuel pumps, that were related, to water in the fuel, grenading the pumps. You may want to do a Google search for VW related HPFP issues. There were extensive discussions about that, and Particulate Filters, over at tdiclub.com. It’s the same technology, so hopefully it will be of some help to you, in terms of cause, and solutions. Best of luck, to you!
/ Kubota catastrophic engine failures #40
I still can't get over the fact that Kubota cheaped out so much on such a sensitive fuel system. Considering how they overprice their tractors so much, would it hurt them so much if they include a simple water in fuel sensor and a light on the dash or an error code? That simple gadget could've saved lot's of money on the owners as they would easily caught the water in fuel before ruin an entire fuel system.
Even the so called "cheap brands" have a water in fuel sensor on models with common rail engines.
You’d laugh if you saw the fuel system on my bigger kubotas
A small, cheap typical water/fuel separator and a smallish fuel filter.
No sensors or indicators.
The “indicator” is the tractor starts losing power or sputtering-usually when you need it most. I have simply resigned myself to 3-4 fuel filters per year.
1999 Toro Groundsmaster 455-D 126in. Mower Commercial Riding Mower (A64194)
1999 Toro...
2016 Chevrolet Silverado 1500 Pickup Truck (A64194)
2016 Chevrolet...
2018 Freightliner M2 106 Elgin Broom Bear Street Sweeper Truck (A64556)
2018 Freightliner...
2019 Komatsu WA380-8 Articulating Wheel Loader (A64194)
2019 Komatsu...
2016 Chevrolet...
Ari-Hetra HDML-8 15,000lb Four Post Auto Lift (A64553)
Ari-Hetra HDML-8...
