5030
Epic Contributor
- Joined
- Feb 21, 2003
- Messages
- 24,772
- Location
- SE Michigan in the middle of nowhere
- Tractor
- Kubota M9000 HDCC3 M9000 HDC
Been contemplating them for a while now. I purchased aftermarket separators but bought the Racor R12T elements with Aquabloc and put them on the aftermarket bases. As expensive as off road diesel is today, the quality of the product can be questionable at times so I felt that additional 'fuel polishing' as well as better water / fuel separation was in order. I contacted Parker / Racor and they recommended the R12T (which has 10 micron filtering capability plus the flow rate (15 gallons per hour) is well in keeping with my diesel fuel usage requirements on both units.
The units are very compact over length with filter cartridges and clear bowls installed is under 12" and the bowls have a provision for draining contaminants plus there is an additional blanked off plug where a electronic water in fuel sensor can be installed to monitor the unit without having to observe it constantly. Not something I need but it is there and Parker-Racor offers the sensor. The R12T filters are spin on to the cast aluminum powder coated base and the clear bowl spins on to the bottom of the filter. Sealing is via neoprene gaskets jut like an lil filter and the bowl to cartridge seal is via 'O' ring. I suggest applying a film of oil or 'O' ring lubricant to both seal's
One of my pet peeves about Kubota's (especially my pre 4 engines is the location of the clear fuel / sediment bowl and the difficulty in accessing it as well as the limited amount of filter in it. The R12T basically eliminates the need to ever having to fiddle with it ever again.
With the new common rail emissions engine and their need for clean, water free fuel, I'd think the R12T filter would be a good addition.
Install is pretty easy too. Find a suitable spot where the unit won't be in harm's way, route the fuel line from the fuel tank to the inlet barb and from the outlet barb to the system. Your lift pump (or gravity flow) will keep the filter full of diesel and the filter base does have an air bleed screw on it if necessary. In my case mounting could be above or below the fuel tank location as mine engines are lift pump fed but if yours are gravity fed, the unit must be below the level of the fuel tank bottom.
