Kioti tractor problem
/ Kioti tractor problem #1
yazooroy
Benton, MS
Kioti
My Kioti tractor's 3 point hitch is stuck in the up position?
/ Kioti tractor problem #2
Turn the drop rate knob near the floor under the seat counterclockwise (rabbit symbol)
/ Kioti tractor problem #3
Ditto, seems to be a common brain fart.
/ Kioti tractor problem #5
The knob on my kioti is way to easy to turn so if I have the hoe on for a few weeks it will almost always vibrate to the closed position, and then I go through the what the **** stage when I try to put the mower on and the arms don't come down right off.
/ Kioti tractor problem #6
OP, welcome to the forum! You don't say what model Kioti you have. If yours has a draft control lever alongside the 3pt lift control lever, be sure you haven't inadvertently pulled it back. That, too, can cause the 3pt not to descend.
/ Kioti tractor problem #7
Since the OP was a 1 and done, we will NEVER know if that was the problem.. (I assume it was, as it often is)
New/Unused Mini Quick Attach Pallet Forks (A65583)
New/Unused Mini...
2006 Ford F-250 4x4 Crew Cab Pickup Truck (A61573)
2006 Ford F-250...
2014 Toyota Tundra Crew Cab Pickup Truck (A64194)
2014 Toyota Tundra...
2017 Western Star 4700 Tri Axle Dump (A62613)
2017 Western Star...
2016 Volvo VNL T/A Sleeper Cab Truck Tractor (A61573)
2016 Volvo VNL T/A...
New 5400LB, Rachet Binders and G70 Chains (A62679)
New 5400LB, Rachet...
