Kioti tractor problem
/ Kioti tractor problem #1
yazooroy
Benton, MS
Kioti
My Kioti tractor's 3 point hitch is stuck in the up position?
/ Kioti tractor problem #2
Turn the drop rate knob near the floor under the seat counterclockwise (rabbit symbol)
/ Kioti tractor problem #3
Ditto, seems to be a common brain fart.
/ Kioti tractor problem #5
The knob on my kioti is way to easy to turn so if I have the hoe on for a few weeks it will almost always vibrate to the closed position, and then I go through the what the **** stage when I try to put the mower on and the arms don't come down right off.
/ Kioti tractor problem #6
OP, welcome to the forum! You don't say what model Kioti you have. If yours has a draft control lever alongside the 3pt lift control lever, be sure you haven't inadvertently pulled it back. That, too, can cause the 3pt not to descend.
/ Kioti tractor problem #7
Since the OP was a 1 and done, we will NEVER know if that was the problem.. (I assume it was, as it often is)
(2) TRAILER FRAME PARTS (A64280)
(2) TRAILER FRAME...
2022 EZ-GO ELITE...
2015 Chevrolet 15 Passenger Express Van (A62613)
2015 Chevrolet 15...
1986 Trailmobile 40Ft F71T-6UJA Trailer (A64194)
1986 Trailmobile...
40' New Container (A62679)
40' New Container...
40ft High Cube Shipping Container (A65583)
40ft High Cube...
