Kioti tractor problem
/ Kioti tractor problem #1
yazooroy
Benton, MS
Kioti
My Kioti tractor's 3 point hitch is stuck in the up position?
/ Kioti tractor problem #2
Turn the drop rate knob near the floor under the seat counterclockwise (rabbit symbol)
/ Kioti tractor problem #3
Ditto, seems to be a common brain fart.
/ Kioti tractor problem #5
The knob on my kioti is way to easy to turn so if I have the hoe on for a few weeks it will almost always vibrate to the closed position, and then I go through the what the **** stage when I try to put the mower on and the arms don't come down right off.
/ Kioti tractor problem #6
OP, welcome to the forum! You don't say what model Kioti you have. If yours has a draft control lever alongside the 3pt lift control lever, be sure you haven't inadvertently pulled it back. That, too, can cause the 3pt not to descend.
/ Kioti tractor problem #7
Since the OP was a 1 and done, we will NEVER know if that was the problem.. (I assume it was, as it often is)
2006 Honda Odyssey Van (A61574)
2006 Honda Odyssey...
UNUSED WOLVERINE HYD AUGER (A64281)
UNUSED WOLVERINE...
2019 Chevrolet Silverado 1500 Crew Cab Pickup Truck (A61573)
2019 Chevrolet...
New/Unused Quick Attach Pallet Forks (A65583)
New/Unused Quick...
UNUSED WOLVERINE QUICK COUPLER 4 (A64281)
UNUSED WOLVERINE...
2021 Felling 29FT FT-45-2LP Trailer (A64194)
2021 Felling 29FT...
