Kioti filter cross reference number list (all models)
   / Kioti filter cross reference number list (all models) #61
I don't think Kioti would admit that the donaldson filter is equal or better than theirs. What would happen if the hst would fail and Kioti saw this filter being used, would they honor their guarantee?
My brand new 2015 NX4510H came with a Donaldson air filter in it. It would be really hard to say "no warranty" since it came with one in it and I replaced it with another one just like it. Oil filter conversion for the E6201-32443 is an AC PF9. I bought 10 of these on EBay for $41.50 delivered. They fit perfect and are a cross-reference to the Kioti filter.
Does anyone have the Baldwin fuel filter number for the Kioti F6800-16411?
   / Kioti filter cross reference number list (all models) #62
Here are the Baldwin numbers for the NX4510HST tractor. I have yet to find the large hydraulic filter made elsewhere.
BT9464 Hydraulic small filter
BF5587 Screw-on Fuel Filter. There is a note saying not to use the water sensor in it.
B173-S oil filter + AC Delco PF9
RS3542 Air Filter
   / Kioti filter cross reference number list (all models) #63
Anyone have issues with the Napa 3507? The inside hole is the right size but the outside diameter of the filter itself is just a bit to big to seat properly.
   / Kioti filter cross reference number list (all models) #64
I did a filter change on my DK40HSE yesterday and the Donaldson P573481 is physically identical to the Kioti gold filter and the tractor functions exactly as it should when I did a test drive.
Jason
   / Kioti filter cross reference number list (all models) #65
hydraulic: Wix 57098 = daedong T2185-38031 and HST: Wix 57350 = T2195-38031
Are we sure of these Wix filters in these applications? I just checked the Wix website for my CK30HST and that machine isn't even listed. When I tried its twin - the Bobcat CT230 - no filter was listed for either the HST or the hydraulics. I would figure if these filters were correct, they would be listed on the Wix website by now.
   / Kioti filter cross reference number list (all models) #66
The Donaldson P573481 filter appears identical in shape to the T4125-38021. Both sealing surface diameters are the same. In particular the one I was questioning before I purchased the Donaldson filter was the internal O-ring that should seal over the protruding tube of the tractor filter housing, which is does. The only visual difference, other than color, is the internal metal mesh pattern. The T4125-38021 has many small round holes where oil passes through. The Donaldson has many rectangular slits that are laid out in a spiral where oil passes through. This tells us that the internal media is different. One thing to note, these two different filters I'm comparing were purchased 2 years apart from each other. (manufacturing may or may not have changed). According to Donaldsons website, this P573481 filter has an 11 micron synthetic media, which is on par for the application. I found no information about relief pressures. I'm not certain they even have an internal relief valve at all. They may not need one, as the tractors HST has its own. Something that could be worth looking into or debating to be sure of. But having said that, there is nothing magical about the daedong HST. The Donaldson P573481 is used widely in Caterpillar machinery within similar systems of equal pressures and fluids. And the filter fits my Kioti quite nicely. I Installed the P573481 in my 2014 DK45 12 running hours ago. No abnormalities thus far. Though I still think their is value in further research. Now If we could just cross reference that T5710-38031....
   / Kioti filter cross reference number list (all models) #67
Just to follow up on my experience with the P573481 on my DK40, I'm probably 10-15 hours in and can't identify any noticeable difference in the operation of my tractor.
Jason
   / Kioti filter cross reference number list (all models) #68
Also, Here is a Spreadsheet I have made of all my cross-referenced filters for my 2014 DK45SEH. I also have volumes, Types, and my own change history on there. Maybe others could find the format useful. I'm not sure if I can put the excel document on here, but this is a screenshot.
   / Kioti filter cross reference number list (all models) #69
Thanks for the spreadsheet, I did copy and paste it.
   / Kioti filter cross reference number list (all models) #70
What make universal trans/hydraulic fluid did you use?
207283 (A52708)
207283 (A52708)
2005 Sterling Acterra Tender Truck (A56438)
2005 Sterling...
(2) UNUSED 460/85R30 TRACTOR TIRES / WHEELS (A57192)
(2) UNUSED...
McFarlane 4025 Reel Disk (A59814)
McFarlane 4025...
2023 Top Air ATV 200 Gallon Pull Type Sprayer with 30ft Booms (A56438)
2023 Top Air ATV...
2011 SOUTHWEST  GOOSENECK (A58214)
2011 SOUTHWEST...
