Kioti filter cross reference number list (all models)
/ Kioti filter cross reference number list (all models) #21
Just paid $205.00 for my ck30 hst filters.
-both hydraulic filters
-engine oil filter
-fuel filter
-air filter
Shazam $200 gone like magic
/ Kioti filter cross reference number list (all models) #22
-engine oil filter
-fuel filter
-air filter
To be honest I don't think $200 bucks for all of that is too bad! Over here a standard hydro filter for a DS3520 is $90, I think the air filter is about $60.00.
/ Kioti filter cross reference number list (all models) #23
I just bought 3 filters for my DK40se HST Hst filter $119.95 hydraulic filter $52.39 oil filter 15.83 plus 15% tax total $216.40 now to go buy the oil..
/ Kioti filter cross reference number list (all models) #24
For a CK 25 oil: Wix 51324
air: Wix 46489
fuel: Wix 33507
HST: Wix 51663
hydraulic: Wix 57098
/ Kioti filter cross reference number list (all models) #25
LJRinWNC what are your Kioti part numbers? I have a DK45se HST will any of those work on it?
/ Kioti filter cross reference number list (all models) #26
oil: Wix 51324 = daedong E6201-32443
air: Wix 46489 = donaldson P822768
fuel: Wix 33507 = daedong 84612-43161
HST: Wix 51663 = wako WP-18
hydraulic: Wix 57098 = daedong T2185-38031
Cant say what will crossover between the DK series and the CK series but maybe this will help.
/ Kioti filter cross reference number list (all models) #28
I'm a newbie here & giving this a bump.
I'm not new to my Kioti DK40 tractor, owned ~ 10 years now.
I've done a fairly exhaustive search for the hydraulic filter for my tractor in an attempt to avoid shipping fees and distant dealers. I'm a former pro wrench and know that there are non-factory filters that easily match OE filters but not interested in a best oil or filter thread:eek: either!
My machine takes the T4620-38032 or 33 Hydraulic filter which sells for around $32-37 as I find it. I'm very rural and local non box AP's store sells WIX filters which is higher on the fuel filter (element type)than the dealer! eBay has the best price on that one, even including the shipping unless I travel to buy one. Oil filters are very common in many brands and cheap enough many places. Hyd. filters are, in fact, heavier steel and different micron elements than the cheapo oil filters but I'd still like to see if anyone has successfully crossed it over to a name brand available locally in AP's stores?
Is there a Kubota cross for the T4620-38033? Be nice as I do have Kubota nearby.
/ Kioti filter cross reference number list (all models) #29
There is NO cross reference HST filter number for the DK series Kioti tractor, unless something new has been discovered very recently, to the best of my knowledge. I can't say whether there is a cross for the regular hydraulic filter, but I doubt it.
If someone has more recent info, please share.
There is no reason to think Kubota, Japan, and Kioti, S. Korea, filters would cross reference.:confused2:
/ Kioti filter cross reference number list (all models) #30
CS2410
The fuel filter is simply as Fram F2. $12.95 for the Kioti version and $3.99 for the Fram version. Not a big savings, but hey, every little bit helps.
/ Kioti filter cross reference number list (all models) #31
I would like to know the thread size/pitch on the hydraulic filter for DK40-it's Kioti part# T4620-38032 0r 33. FWIW, I'm not being lazy, just don't have a loose one to measure.
/ Kioti filter cross reference number list (all models) #32
I have found aftermarket crossover filters for everything on a DK45S except for the Hydraulic
Fuel Wix 86397 (This spin on does not have the drain on bottom but you really do not need that anyway unless you have water in your fuel)
Oil Wix 51324 $6.95
Air Wix 46489 $48.00
Car Quest brand
Oil 85324
Air 88489
Fuel, Have not purchased that one yet
Oreilly, NAPA, and Car Quest all sell Wix Filters
/ Kioti filter cross reference number list (all models) #33
Update for me- I now have a new Kioti OE Hyd. filter (that I can measure as posted above) to use soon.
The oil & air filters are an easy find, the fuel varies with model-mines a serviceable, glass type.
/ Kioti filter cross reference number list (all models) #34
I have Kioti nx4510 and do not see any cross reference for the main fuel filter which is F5800-16411 listed in hand book. Anybody got any ideas about that one? Seems like I found it on a few sites ranging from 80 to 115 bucks!:shocked:
/ Kioti filter cross reference number list (all models) #35
I finally came up with cross reference numbers for the CK20 Hydraulic Filters.
There is a Swiss Filter company HIFI Filter they cross reference the big filter, T4260-38125. to their SH 60021. After a bit of digging.
That gives us Donaldson P551779, WIX 57098, NAPA 7098.
A similar process for the small filter, T2195-3803, gives WIX 57350, NAPA 7350, FRAM P7076, Baldwin BT8898.
/ Kioti filter cross reference number list (all models) #36
How about a air filter for a DK35 with Daedong engine? Kioti #E6300-11081 this is the outer filter. I crossed it to a wix 42222 won't fit. The wix filter will not go over inner filter.
Wix website does not give a cross reference for Daedong engine.
May have found a wix 46389 that will work. The inner opening is 7mm bigger and the hole the bolt goes thru is 5mm bigger but I think it will work.
Anyone else tried to cross this filter?
/ Kioti filter cross reference number list (all models) #37
I recently installed a Napa inner air filter on my DK-40. I had trouble initially getting the OEM outer filter to fit over the inner one, I think mostly due to being unable to tilt the bigger filter, not having enough room to fit it over the end of the inner filter.
I'd suggest making sure the inner filter is completely seated on it's 'tube' at the inner end of the filter housing, and then, as needed you may have to loosen the entire housing to be able to slide the bigger outer filter over the inner and then reassemble the entire unit. The actual housing is keyed to fit a certain way so take a close look at that too. It's like a Rubric's cube in a small space.
Sorry I don't have the Napa inner filter # on hand at the moment.
Post back results.
/ Kioti filter cross reference number list (all models) #38
My DK35 is older model has the Daedong engine. I wound up taking out the inner filter and installed the wix 42222 filter. This filter is listed for everything under the sun from A to Z. Gas,diesel, tractors, construction equipment, forklifts you name it.
If it is good enough for these other machines should work just fine in my little tractor. Cost me 20 bucks for the filter so I can change it often if needed. If it gives me a home made bore job I will know it was not the right choice to make. Wish me luck.
/ Kioti filter cross reference number list (all models) #39
Most of the Kioti air filters were Donaldson brand filters. If you check the rubber on the end of the filter, you should see the name Donaldson and then the Donaldson filter part number. Try crossing with that Donaldson number.
/ Kioti filter cross reference number list (all models) #40
Will look and see what I can find.
2022 SANY SY50U EXCAVATOR (A63276)
2022 SANY SY50U...
2022 Mac Trailers 48ft. T/A Walking Floor Trailer (A64556)
2022 Mac Trailers...
2022 EZ-GO ELITE...
2010 Chevrolet Tahoe SUV (A64194)
2010 Chevrolet...
2020 VOLVO EC200EL EXCAVATOR (A65053)
2020 VOLVO EC200EL...
2021 Scag Turf Tiger II 52in Zero Turn Commercial Mower (A64194)
2021 Scag Turf...
