Kioti filter cross reference number list (all models)
/ Kioti filter cross reference number list (all models) #41
I was able to find oil, hydraulic and HST filters for my CK35HST on tractorjoe.com.
The hydraulic filters were in the $35 range each, oil filter was $10. Standard shipping on all three was around $20.
/ Kioti filter cross reference number list (all models) #42
Be careful of tractor joe's. I ordered a $100.00 HST from there and they sent me a counterfeit filter. I ordered the OEM filter and got what I think was a Baldwin. I did get my money back though.
/ Kioti filter cross reference number list (all models) #43
Couldn't find a part number of any kind on old air filter. Tried cross reference on Donaldson site no cross reference found. Oh well the wix 42222 should do just fine. This is for DK35 with Daedong engine.
/ Kioti filter cross reference number list (all models) #44
Kioti part numbers for the NX series:
NX series hydraulic filter T4620-38033
NX series HST filter T4125-38021
NX series engine oil filter E6201-32443
The Donaldson air filter is P827653
I do not know of any cross-references for the Kioti branded filters. The Donaldson air filter cross references everywhere and is available from Donaldson on Amazon.
/ Kioti filter cross reference number list (all models) #45
So I gave my local diesel shop a call asking about the hydrostatic filter. I used this part number T4125-38021 which I got off a kioti parts website. The diesel shop claimed that Donaldson has a filter here is the website I checked it at Donaldson P573481 HYDRAULIC FILTER, SPIN-ON Engine & Hydraulic
The Kioti parts website shows a connection adaptor part#T4125-38051. The link above shows a filter that looks like it would fit with an oring to go onto the adaptor. Any thoughts?
The kioti parts website I'm using is
Kioti Parts
/ Kioti filter cross reference number list (all models) #46
I should mention my Kioti is a DK40SE HST
/ Kioti filter cross reference number list (all models) #47
Just my two cents, but I cannot understand investing $20,000+ on a tractor and then looking to save peanuts on filters, some of which, you, given most use, will change every 2 years. In some cases, a cross reference is "closest to factory specs" not necessarily equal to factory specs and a hydraulic filter is a different animal than an oil filter. Do a search of this site for dealers, one very good one in Michigan comes to mind. They can set you up with the real thing and the $$$ is not that bad.
/ Kioti filter cross reference number list (all models) #48
Donaldson is the cream de la cream of filter manufacturers and is likely the OEM of these filters. NXes use the same filter. Donaldson Hydraulic Filter - P573481 – Donaldson Filters
/ Kioti filter cross reference number list (all models) #49
Crap! Ran across this info a bit late. I just spent $101.54 for that Kioti filter!
/ Kioti filter cross reference number list (all models) #50
It does take guts to use the cross referenced donaldson hydraulic filter in place of the kioti to save 60 bucks. Would be nice if the substituted filter was verified.
/ Kioti filter cross reference number list (all models) #51
And is thats the HST filter or the hydraulic filter. Big difference in price.
/ Kioti filter cross reference number list (all models) #52
I believe it's the HST filter
/ Kioti filter cross reference number list (all models) #53
Why does it take guts?
As Eric noted above, Donaldson isn't Fram;) And, Eric should know, Donaldson is a Minnesota company!
Keep in mind that Kioti doesn't spec anything exotic for their fluids. In this case it's about the filtration level and pressure cutoffs; and here too, I doubt that anything magical (above industry norm) is happening. Just comes down to whether it's a quality filter.
FYI - The Kioti 38021 filter weighs in at around 1 3/4 lbs (less 1 oz - you do the math)
/ Kioti filter cross reference number list (all models) #54
I don't think Kioti would admit that the donaldson filter is equal or better than theirs. What would happen if the hst would fail and Kioti saw this filter being used, would they honor their guarantee?
/ Kioti filter cross reference number list (all models) #55
My sister worked for Donaldson as a Senior Process Engineer (she designed and set up assembly lines) up until a former company she worked for 20 years called her up and asked her to come back because they needed to make Honda and Chrysler parts.
/ Kioti filter cross reference number list (all models) #56
has anyone actually verified that the donaldson hst filter is the same as the genuine kioti filter? This would be a big savings.
/ Kioti filter cross reference number list (all models) #57
Kioti Parts
Has anyone actually verified that the donaldson and kioti hst filters are the same?
/ Kioti filter cross reference number list (all models) #58
From what I can see without cutting the things apart, the HST filter looks the same (as in the tool marks). I can also tell you that years ago my sister built the assembly lines for this type of filter in a couple of Asian locations. Sadly I never asked for confirmation while she worked at Donaldson but what I can share is that Donaldson wanted her skill set after she had built assembly lines for Apple iPods at FoxCom and the original Mac Airbook (meaning shedloads of robotic machining and finishing tools) before her original employer hired her back to build assembly lines for auto parts again.
/ Kioti filter cross reference number list (all models) #59
Is there any way to find out if donaldson makes the hst filter for kioti?
That would be like a $60.00 savings.
/ Kioti filter cross reference number list (all models) #60
I just got off the phone with donaldson. They said that the Donaldson P573481 is made by Hitachi, and is a good cross-reference to the kioti T4125-38021 HST filter.
2015 Ford Explorer SUV (A61574)
2015 Ford Explorer...
New/Unused Wolverine Quick Attach 72in Grapple Bucket (A65583)
New/Unused...
Landhonor 8'x10' Galvanized Apex Metal Shed (A62679)
Landhonor 8'x10'...
2011 Honda Civic Coupe (A61574)
2011 Honda Civic...
2012 FORD SERVICE TRUCK (INOPERABLE) (A65643)
2012 FORD SERVICE...
KNOW BEFORE YOU BID - DO YOUR HOMEWORK AND BE HAPPY WITH YOUR PURCHASE (A65053)
KNOW BEFORE YOU...
