Kioti filter cross reference number list (all models)
/ Kioti filter cross reference number list (all models) #101
The site will not allow me to edit my post #98, so here is the continuation:
2017 Kioti CK2510(H)
Engine Oil Filter = WIX 51381*
Hydraulic Filter = WIX 57098**
HST Filter = WIX 51663***
Fuel = WIX 33507 is not correct for this 2510 tractor, the diameter is too large. I will be trying another # soon from my NAPA dealer.
* (That would make it a NAPA 1381) and it worked fine. Same/similar outside dimensions, correct spin-on threads, and the seal diameter measures the same as the original Kioti factory filter.
**This is the long one, underneath, mounted vertically. Same diameter, same length, same seal diameter. Internals look pretty much the same as factory filter. Those who have reported that this factory filter is hard to remove the first time are correct. It was a bear! I used an old universal coiled spring style filter wrench to grasp it with a 1/2" breaker bar for leverage. Was still a struggle. Be prepared for a workout.
***This is the one by your right heel, near the floor board, mounted horizontally. This filter appeared the same diameter as the factory HST filter, except it is slightly shorter. I actually like this, as the factory filter stuck out quite a bit and my heel would rub on it. This filter is still long enough to protrude so that you can get a filter wrench (strap or cap style) on it for removal next time. You can cross reference this WIX# on the WIX site and possibly get one that is the same length as factory, I have not done that yet.
/ Kioti filter cross reference number list (all models) #102
Greetings.
I'm due for a change for all filters and so I was rereading this thread.
I've been using WIX 51324 (NAPA Gold1324) for my oil changes. I used Kioti HST and Hyd the first time around (I owed the dealer). Tis time I was looking to see what's available.
Cummins Filtration - Catalog - Part Search says there is no cross reference for the T2185-38031 or the T2195-38031.
WIX said :
Part Number Manufacturer Wix Part Number
76KD10331 KIOTI 33389 Fuel Filter (NAPA 3389)
P821575 DONALDSON 46438 Air Filter
Part Number Comments
T219538031 This is a valid competitive part number and there is no replacement at this time. (HST filter)
T218538031 This is a valid competitive part number and there is no replacement at this time. (Hyd Filter)
Where did you get info on the HST and Hyd filters?
BTW nice to see another CK2510 owner.
/ Kioti filter cross reference number list (all models) #103
I've been searching prices and I can't believe what I'm finding. The WIX 51663 is listing at $7.86 (Rockauto), $8.14 (FleetFilters), $6.90 - $14.69 (eBay) and $24.98 (Jet.com) vs $23.51 and $33 for the Daedong T2195-38031 filter. The WIX 57098 is more even across the board $24.79 at RockAuto, $36.66 at TraderJoes and $42.70 at my local Kioti dealer for the Kioti filter.
I'd save the money if I could be sure it's a comparable filter but I can't find any specifications for Kioti filters.
/ Kioti filter cross reference number list (all models) #104
Is there a way we can make a searchable database for user verified cross-references and imbed it in the site? I think that would be a huge value add.
/ Kioti filter cross reference number list (all models) #105
It would be nice to have such a search element. But I imagine there would be some liability issues about who is responsible for the accuracy of the list. When I'm looking for something specific on a forum about a new filter, and I want to see if anyone has said anything about it within the forum, I've found searching through google, specifically with the website you want to search through, works pretty good.
Example, if I'm looking for anyone who has mentioned the new Wix WL10113, a cross reference for Kioti T4620-38032, a DKse hydraulic filter, I type into the google searchbar, "site:TractorByNet.com | Compact tractor forums, news, reviews, information. wix wL10113 kioti T4620-38032". this will only show results from tractorbynet, with those key words
/ Kioti filter cross reference number list (all models) #106
Well, as with any information you find on a forum or the internet, the user needs to assume responsibility for what they do with the information they find.
Maybe I'm just a little bit lazy, but sometimes I search for hours, only to find out the one source for information wasn't tagged right, or some different terminology was used, thus hindering my search.
Thanks for the hydro filter cross reference, that's one I've been looking for. :)
/ Kioti filter cross reference number list (all models) #107
:drink:
I haven't found the Wix WL10113 available online just yet, but the napa cross is 400113, which i see is available online, for about the same price as kioti. So at this point I have a cross for every filter for the DKse tractors. Cant say that about many tractors these days.
/ Kioti filter cross reference number list (all models) #108
:drink:
I thouth that NAPA filters are made by WIX. The part # is usually the same with one leading digit removed.
/ Kioti filter cross reference number list (all models) #109
Yes thats right, but for some reason the filter is not available as a branded Wix filter. Just Napa. Also, the numbers are not what we would usually find for a Wix to Napa branding. This Wix number WL10113 should be a Napa 0113, but its not, its Napa 400113. So there is something going on here that's out of the ordinary.
But this Napa 400113 it's still a good crossover for the kioti T4620-38032 according to both Napa's and Wix's websites.
/ Kioti filter cross reference number list (all models) #110
Any filter cross references for a LK3504?????
/ Kioti filter cross reference number list (all models) #111
May be a repeat but I can confirm.
2013 DK45SE
Napa oil filter 1324
Wix fuel filter 33507
I went to find a fuel filter after checking here. Usually my NAPA store is very good but they are closed on Sundays, so I had to go to the competitor down the road. I walk in and here is what transpired with the kid behind the counter.
Me - I need a fuel filter for my tractor (he didn't let me get any further)
Kid - We don't sell tractor parts , you'll have to go to tractor supply
Me - You can't cross reference a Wix number?
Kid - yes, but we don't carry wix filters for tractors
Me - it is number blah, blah, blah
Kid - comes back with a Wix filter in his hand.
Good grief
/ Kioti filter cross reference number list (all models) #112
Also, Here is a Spreadsheet I have made of all my cross-referenced filters for my 2014 DK45SEH. I also have volumes, Types, and my own change history on there. Maybe others could find the format useful. I'm not sure if I can put the excel document on here, but this is a screenshot.
Still got you your spread sheet kicking around?
Would love to have a copy.....please
/ Kioti filter cross reference number list (all models) #113
could get a copy of you spread sheet?
Saves time on recreating it
to emulate it to compliment.
Tim
/ Kioti filter cross reference number list (all models) #114
You can put the kioti part number in the cross reference on Wixç—´ website and it will give you two Wix part numbers. Both will work but one is a little taller but about an inch. My kioti DS4110 will fit both. Just measure the distance between the filter and the closest panel or obstruction and if you have at least an inch clearance, youæ±*e good.
/ Kioti filter cross reference number list (all models) #115
Just used the WIX lookup and found my filter first shot. Thanks
/ Kioti filter cross reference number list (all models) #117
From what I have found for a Baldwin is this
Hydraulic
Daedong=T2185-38031, Wix=57098, Baldwin=BT8488
HST
Daedong=T2195-38031, Wix=57350, Baldwin=BT8898
/ Kioti filter cross reference number list (all models) #118
I am going to give these Baldwin filters a try hope they are the right ones 🤞. Everything I can find says they should work
/ Kioti filter cross reference number list (all models) #119
Tear apart a Wix filter before you use it on your expensive to fix transmission. If you have any problems under warranty and it goes back to the dealer you can kiss the warranty bye bye.
/ Kioti filter cross reference number list (all models) #120
Technically, so long as the replacement filter meets or exceeds the performance of the oem filter, the Magnuson-Moss Warranty Act prohibits the tractor manufacturer from voiding the warranty based solely on its use. But how do you show that? The burden of proof will be on the consumer to establish that equivalency. As a practical matter, that's a tough row to hoe for a tractor owner in the absence of published and verifiable specifications for the replacement that can be matched up closely with the oem specs. Even then, the tractor manufacturer might dispute the equivalency for the particular application, and the tractor owner is then left with the expensive remedy of litigation. That will mean the additional cost of bringing in an expert witness to testify to equivalency. :eek:
Just something for all of us to keep in mind when trying to save money by trying to cross-reference HST and hydraulic filters for tractors that are still under warranty.
3144 (A63117)
3144 (A63117)
24Wx25Lx12H Two Car Metal Garage | Durable Metal Garage
24Wx25Lx12H Two...
Massey Ferguson 2605 (A64126)
Massey Ferguson...
New/Unused Landhonor 21ft x 13ft Metal Carport (A65583)
New/Unused...
John Deere 6110M (A60462)
John Deere 6110M...
2019 ALLMAND LIGHT PLANT (A65643)
2019 ALLMAND LIGHT...
