Kioti filter cross reference number list (all models)
/ Kioti filter cross reference number list (all models) #81
/ Kioti filter cross reference number list (all models) #82
The Wix 51324 oil filter is too long for my 2013 CK30, and the cover plate will not go on with that filter installed. At Wix Filters - Product Catalog search results it shows Wix 51324 and Wix 51381 replacements for the E620132443 original Daedong filter. The Wix 51381 is also about the same length as the Daedong 620132443, fits nicely on my 2013 CK30 and has about the same bypass pressure as the Wix 51324. The Wix 51381 should be a good replacement since it's directly cross refer3enced in above link. Hopefully this info will prove useful for others who find the Wix 51324 too long to fit correctly. BTW I also learned the Microguard MGL51381 the same filter as the Wix 51381 and is made by Wix for O'Reiley's Auto Parts, and it costs about $3 less than the Wix brand.
/ Kioti filter cross reference number list (all models) #83
I have the same problem with my CK35. the Napa 1324 is 3/4" longer than the Koiti engine oil filter. the side cover will go on, but rubs on the filter. I put a 2" dia. piece of self stick 1/2" neoprene on the filter and all is well.
/ Kioti filter cross reference number list (all models) #84
On my CK30 the cover plate actually put a slight dent in the filter, and I think adding neoprene would just add to the problem, and the Wix 51381 (or Napa 1381) will be a better solution in my case.
Also last fall I had a hole punched in the Wix 57098 hydraulic filter requiring filter replacement plus about 2.5 gallons of hydraulic fluid, and the same thing happened last weekend. I was trying to think of a way to add a protective plate, bracket or something to protect the filter. Has anybody else had this problem or devised a solution to the problem?
I just had my password reset which seems to be random letters/numbers. Is there a way to reset password to one that I choose to make it easier to remember?
/ Kioti filter cross reference number list (all models) #85
After you log in with the self generated password, look at the top center of the page for the gear looking picture that states "My Home". Click that and then look at the left of the page for change email/password.
Your not the first to punch a hole in the filter. Some members have reported hitting the filter hard enough to break the filter mount which can leave you stranded with hydro fluid pumping out. Do a post search. I remember seeing a posting/picture where a skid pan was made. Nothing for just filter protection though if I remember correctly.
/ Kioti filter cross reference number list (all models) #86
Found a post at the second link at Search Results | Compact tractor forums, news, reviews, information. that has photos of skid plates added to a DK40, and the 4th photo in reply #16 there shows skid plate protecting hydraulic filter. I can't recall if my CK30 has a frame piece like the 1 in that photo to attach a skid plate, or maybe that poster added that piece to which to attach the skid plate. Does anybody know if the piece the skid plate is attached to in that photo comes on a DK40 or how it might have been added if it doesn't come on the DK40?
That idea should work if I can find something to attach the skid plate to on the CK30, but I think that skid plate could be improved by having it curve up a few inches on the ends. The incident last weekend I suspect was caused by a rock or piece of gravel was hit by the bush hog blade and launched into the filter causing the puncture, and a skid plate curved up on the ends would have prevented the rock or gravel from impacting the filter.
Edit: The post I referred to above was the second link on that page but is now the third link. To clarify it's the link titled "Skid plate - page 2" in case it changes again due to other links that may appear on the page.
/ Kioti filter cross reference number list (all models) #87
We may be able to purchase an alternate filter for the T5710-38031 Hydraulic filter soon. The Wix website is showing a cross reference part number of WL10113. I can't find it for sale anywhere on the internet but I am calling Wix customer service tomorrow to see what they say.
/ Kioti filter cross reference number list (all models) #88
I get the same when I search for the older hyd filter version T4620-38032. This is a great development, hopefully it will be available soon. The final filter cross reference.
/ Kioti filter cross reference number list (all models) #89
I was at my dealer's recently picking up filters for my 200 hr service and the hydraulic filter (or trans filter?) was $40 cheaper this time around. Be interesting to see how the prices match up.
/ Kioti filter cross reference number list (all models) #90
Wix told me that the WL10113 is not in production yet and they could not provide a time frame as to when it will be available... so we must wait...
/ Kioti filter cross reference number list (all models) #91
I could never really understand why anyone would spend $20,000 plus dollars one a piece of equipment and make them selves crazy trying to fine a alternate filter for their piece of equipment. I know some Kioti filters are on the high side but why kill yourself to save a few dollars. For example a JD filter for my 355R is almost 20 dollars and B/S filter is 14,00 dollars and a puralator filter is 5.99 at auto zone. I have a CK30HST and really never had a problem with filters. I keep 4 oil filters 4 fuel filters on hand and have changed both hydraulic and transmission filters at least three times keeping up with the Kioti specs. Use a good oil Rotella for example change in the spring with Rotella 15W30 and I use a Rotella 5W30 synthetic in the fall for winter starting. It might be overkill but I don't want to buy another tractor. I ALSO HAVE A 19518n and a 1955 ACWD and use Rotella in all of them and every piece of equipment I have. I am not suggesting that I am correct but it works for me. Good luck all.
/ Kioti filter cross reference number list (all models) #92
When you're looking at over $100 for a filter one tends to pucker more. WIX and Donaldson, which are the more likely aftermarket filter manufacturers that we'd be looking at (Kioti's air filters are Donaldson- look right there on the canister). A few bucks is one thing, but a $60 difference is another (which is the case with hydraulic filters, not engine oil filters). And when you have a lot of equipment it really starts to add up.
/ Kioti filter cross reference number list (all models) #93
Having a cross referenced filter for me is a great piece of mind. I no longer have to rely on just a dealership to get filters quickly. Redundancy is a good thing. Plus, a wix filter is far from risking your expensive equipment. It's getting good quality without the corporate mystery markup. But also, many folks have to pinch $$ wherever possible. Sure a filter alone may not save much buying a cross reference, but add all the small things like this up wherever possible and it becomes considerable $$. Small farming only yields a profit if you can be very thrifty everywhere possible. In many fields, buying a Wix, or Donaldson to save $60 on one filter is a no brainier.
/ Kioti filter cross reference number list (all models) #94
Is this list compatible with a 2016 DK4510? Needing to change my oil and was wondering.
/ Kioti filter cross reference number list (all models) #95
I don't believe so. The DKse tractors are the predacessor to the NX. Not related as much to the newer DK10 series as the name might imply
/ Kioti filter cross reference number list (all models) #97
BF5587 Screw-on Fuel Filter. There is a note saying not to use the water sensor in it.
Be careful using a fuel filter without a place for the water sensor.
Tractor models with a water sensor monitor this sensor and shut the unit down to an idle if it detects too much moisture.
The reason is that if any moisture reaches the common rail injector pump, the pump is typically ruined.
/ Kioti filter cross reference number list (all models) #98
2017 Kioti CK2510(H) Engine Oil Filter
I just used a WIX 51381 filter (That would make it a NAPA 1381) and it worked fine. Same/similar outside dimensions, correct spin-on threads, and the seal diameter measures the same as the original Kioti factory filter.
I will edit and add Fuel, Air, Hydraulic and HST as they are changed and verified.
/ Kioti filter cross reference number list (all models) #99
SkunkWerX, do you know if the cut-off pressure on the WIX is the same as the stock/factory one?
I struggled mapping a third party oil filter for my old generator. Didn't want to shell out big $$ for something with "Cummins" on it, when it's a Kubota engine! The WIX I got for it had a different cut-off pressure. I gambling a bit, but I don't run the generator much. To be honest, I'm not real sure exactly how the cut-off pressure would come in to play in a real life scenario.
/ Kioti filter cross reference number list (all models) #100
I ran WIX and Pure One engine oil filters on my Kubota BX for almost 2,000 hours, with no issues.
The cut off pressure range was right in there.... maybe off by 1 psi at one end or the other. I really had good specs on the WIX end of things and considering how sketchy the Kioti information can be, I didn't really stress over it too much. I can see where a generator might potentially be a different animal, but I think you will be fine. I think the worst case scenario on any good quality oil filter is that it goes into bypass? Still flowing, doesn't blow off, engine is still lubing, just not filtering any more. The bypass is just a rubber valve, so i think that's why the manufacturers give us a range, because it probably varies a little between each of their filters.
Side Note: I have read about Kioti owners having smoke on start up. I was getting a little bit of smoke on the factory oil and filter. It is still warm weather, but I started hitting the warming element before cranking, and that took most of the start-up smoke away. New tractor, I figure the piston rings and valves are still seating and the smoke wasn't excessive so I just watched it. NOW, after doing the oil change, no smoke, at all, on start up! Also, it barely cranks on start up, just hit the key and it pretty much fires on the first revolution. I have less of that gravelly diesel sound and less engine vibration at idle. Anyone getting close to the 50 hours, don't hesitate, get that factory engine oil out of there, use a premium grade 15w40 diesel engine oil and hopefully you will see the results I just experienced.
It made a difference.
2016 HAMM H7i SMOOTH DRUM ROLLER (A60429)
2016 HAMM H7i...
UNUSED SDLANCH 14' BI-PARTING IRON GATE (A64281)
UNUSED SDLANCH 14'...
2005 Komatsu PC 200 LC (A60462)
2005 Komatsu PC...
2015 Chevrolet Silverado Pickup Truck (A62613)
2015 Chevrolet...
2015 Hitachi ZX75US Midi Excavator (A61572)
2015 Hitachi...
1999 22ft Sea Ray Boat w/ 2015 23ft Shorelander T/A Boat Trailer (A61574)
1999 22ft Sea Ray...
