Kid snaps loader arms
/ Kid snaps loader arms #21
I snapped both loader rams on a John Deere a few years ago. I had a full bucket raised fairly high, hit a bump and "Snap". Lower the bucket before racing down the trail! That cost me $1100.
I have only been tractoring for a few years, but the one thing I have learned is never do anything FAST with a tractor.
Most bad stuff gets worse when you have 3000-plus pounds of momentum happening.
/ Kid snaps loader arms #22
Amen. I was moving dirt from a pile about 100 yds away and just wanted to git-er-done. Cost me money, 3 lost days and it wasn't even my tractor. Lesson learned.
/ Kid snaps loader arms #23
My boom cylinders leak down, I don't notice when running but if I leave it parked for an hour the loader ends up on the ground. I suspect I created the issue by improper backdraging. Lesson learned.
/ Kid snaps loader arms #24
I should probably read up on the "Proper" way to backdrag also. My last backhoe was a Case 580 and was indestructible.
/ Kid snaps loader arms #25
Not sure how remote you are but around here there's a couple people who repair cylinders. What they do is cut off the end of your rod, use new rod machined to match what you have and weld the old end on the new rod rebuilt with new seals. The price is cheaper than anything I could find used or for a generic cylinder. When I got my 580k someone had bent one of the swing cylinders so I did the homework. I've had it now 14 years after being repaired without any problems.
/ Kid snaps loader arms #26
Never even crossed my mind that those cylinders could be repaired. Since the tractor wasn't mine, I felt compelled to replace with new.
/ Kid snaps loader arms #27
That's my second rule about borrowing; don't use it if I can't afford to fix it. (First rule is; don't lend anything if I'm going to want it back.)
/ Kid snaps loader arms #28
Or better to give than to lend, because the price is the same.
I guess on the bright side, that so many people don't know what a tractor loader is made for, is good for all kinds of business income.
/ Kid snaps loader arms #29
That is my rule for money...I gift it, if able. I will not "Loan" as that normally ends friendships. The Tractor will not leave the property unless I am in the seat. I will help you.
/ Kid snaps loader arms #30
FWIW, I too thought Messik's response was a little harsh, considering the circumstances, and the OP stated he has some difficult saying exactly what he meant, in his title.
Coming from a non-dealer the comment might have been less taken as a criticism, so I can see both sides of the argument.
Nonetheless, I do feel there might have been a better way to apprise users of the backdrag 'rules'.
I too learned the hard way about backdragging- but did not suffer cylinder damage. I did bend the 1/2 moon shaped pieces on the front of my first tractor, a DK-35 Kioti.
They were replaced under warranty, then I bent them again. Dealer welded support bars on them. I bent them again, and decided to trade up within a year of the first, and traded to a DK-40. This solved a bunch of my issues, stronger loader, etc. Cost me about 8K to move up, loss on used 1st one and cost to go to bigger/newer model.
I'm more than happy now, and have learned its a tractor, not a dozer - who knew?! :confused3:
/ Kid snaps loader arms #31
What is the Proper way to backdrag with a compact tractor? I think my owners manual said to keep the bucket flat on the ground and not with the bucket curled down. Not very intuitive when used to a big loader.
/ Kid snaps loader arms #32
Why not forget the tractor then? Save some fuel and simply drag a plastic snow shovel behind you for the same result.
/ Kid snaps loader arms #34
Depends entirely on how much intuition you have.
/ Kid snaps loader arms #35
The back drag issue is normally associated with having the bucket curled down to a point that the leading edge will catch on stumps, etc causing excessive pressure on the extended cylinders. Having a slight down angle that the bucket can jump over obstacles normally doesn't cause issues with bent or broken cylinder rods.
/ Kid snaps loader arms #36
Thanks. That makes sense.
/ Kid snaps loader arms #37
Also, for those with less skills at doing things like backdragging; using the loader float position keeps from damaging their loader cylinders.
/ Kid snaps loader arms #39
The "heel" of the bucket is what I usually use to backdrag. Ideally in float. But sometimes powered down to the point of lifting the front wheels.
I HAVE been guilty of backdragging with the teeth, particularly when trying to clear roots and such. No damage to date (about 10 years and 400 hrs). The Kubota LA loaders are TOUGH!
/ Kid snaps loader arms #40
Front end loaders were never designed for earth engaging tasks or abuse. Having said that, I wouldn't think that given the moderate energy limitations of a small tractor, that a loader designed for a given tractor, should break that easily.
I can see, that high inertial loads can break just about anything, but the tractive effort alone of a small tractor, breaking the loader???
So why wouldn't they spend another fifty bucks at the manufacturing level and put in beefier loader cylinders? Then backdrag all you like!
3pt 6' Countyline Rake (A64126)
3pt 6' Countyline...
2013 CHEVROLET 2500 HD (INOPERABLE) (A65643)
2013 CHEVROLET...
Vermeer 604 XL-Series (A62177)
Vermeer 604...
Frontier Root Grapple (A64126)
Frontier Root...
1999 AMERICAN EAGLE CLASS A MOTORHOME (A65643)
1999 AMERICAN...
(10) New CATERPILLAR Keys (A65579)
(10) New...
