john deere 4200
/ john deere 4200 #1
kcaver
kentucky
john deere 4200/L130
tractor was working fine and then all of the sudden (hydrostatic) would not go forward or backward. 2 years ago I had this quy work on it and he showed me a really gunked up filter from transmission. I have drained the hyd fluid/transmission myself and pulled the screen out to clean. This is not the same as he showed me a couple of years ago. I hope cleaning the screen and putting in new fluid will fix the problem. any suggestions?
/ john deere 4200 #2
Did you try it all gear ranges? Sometimes mine gets stuck in between ranges if I bump the lever. Just thought.
M.D.
/ john deere 4200
I did not try that, but I will, thanks.
/ john deere 4200 #4
On my recently aquired used JD4200 it can be a little akward getting the range selector into the middle range. Of course I am not very familiar with it yet having only put maybe 15 hours on in usually low range mostly clearing snow.:D
/ john deere 4200 #5
I leave mine in the middle range unless I'm doing ground engaging work. It is a pain to get back in the middle range on the first try.
M.D.
/ john deere 4200 #6
Not typical to lose drive in both directions all at once. Check the following:
- oil level
- sump screen
- change spin on filter
- linkage from pedals to hydrostatic trans. (Get under and have someone actuate the pedals, you'll see if something is loose/disconnected)
After you have performed the above, do you have steering?
If yes, your pump is good and I would next focus on the charge pressure relief valve. if it is weak/failed/stuck open, you will lose drive.
-If you don't have steering, it is probably your pump.
That should keep you busy for a while, good luck.
P.S. Be certain the change the spin on filter on a regular basis because as designed when the filter clogs it bypasses oil around it right back into the system. This will feed dirty oil into all hydrostatic/hydraulic compoents and wear/fail them prematurely. I would change mine every 6 months. Cheap insurance.
/ john deere 4200
I do have steering, so that makes me feel better. I have new filter and cleaned the suction screen and getting ready to put it all back togerter. thanks for your help.
k
/ john deere 4200 #8
So what was the outcome?
ROOF RACK (A68842)
ROOF RACK (A68842)
GENERAC MOBILE  MTL65 LIGHT PLANT (INOPERABLE) (A67714)
GENERAC MOBILE...
2018 GENERAC MOBILE PRODUCTS  MTL6S (INOPERABLE) (A68842)
2018 GENERAC...
2018 HITACHI ZX470LC-6 EXCAVATOR (A65056)
2018 HITACHI...
2009 Chevrolet 3500HD (A64911)
2009 Chevrolet...
2012 FREIGHTLINER M2 6X4 T/A DAY CAB TRUCK (A66091)
2012 FREIGHTLINER...
