john deere 4200
/ john deere 4200 #1
kcaver
kentucky
john deere 4200/L130
tractor was working fine and then all of the sudden (hydrostatic) would not go forward or backward. 2 years ago I had this quy work on it and he showed me a really gunked up filter from transmission. I have drained the hyd fluid/transmission myself and pulled the screen out to clean. This is not the same as he showed me a couple of years ago. I hope cleaning the screen and putting in new fluid will fix the problem. any suggestions?
/ john deere 4200 #2
Did you try it all gear ranges? Sometimes mine gets stuck in between ranges if I bump the lever. Just thought.
M.D.
/ john deere 4200
I did not try that, but I will, thanks.
/ john deere 4200 #4
On my recently aquired used JD4200 it can be a little akward getting the range selector into the middle range. Of course I am not very familiar with it yet having only put maybe 15 hours on in usually low range mostly clearing snow.:D
/ john deere 4200 #5
I leave mine in the middle range unless I'm doing ground engaging work. It is a pain to get back in the middle range on the first try.
M.D.
/ john deere 4200 #6
Not typical to lose drive in both directions all at once. Check the following:
- oil level
- sump screen
- change spin on filter
- linkage from pedals to hydrostatic trans. (Get under and have someone actuate the pedals, you'll see if something is loose/disconnected)
After you have performed the above, do you have steering?
If yes, your pump is good and I would next focus on the charge pressure relief valve. if it is weak/failed/stuck open, you will lose drive.
-If you don't have steering, it is probably your pump.
That should keep you busy for a while, good luck.
P.S. Be certain the change the spin on filter on a regular basis because as designed when the filter clogs it bypasses oil around it right back into the system. This will feed dirty oil into all hydrostatic/hydraulic compoents and wear/fail them prematurely. I would change mine every 6 months. Cheap insurance.
/ john deere 4200
I do have steering, so that makes me feel better. I have new filter and cleaned the suction screen and getting ready to put it all back togerter. thanks for your help.
k
/ john deere 4200 #8
So what was the outcome?
ENCLOSED OPERATOR CAB (A67714)
ENCLOSED OPERATOR...
Eagle Line 3pt 5' Box Blade (A64911)
Eagle Line 3pt 5'...
2019 Peterbilt 520 T/A EZ-Pack 40Yd Front Loader Garbage Truck (A66736)
2019 Peterbilt 520...
GENERAC MOBILE PRODUCTS  MTL6S (INOPERABLE) (A67714)
GENERAC MOBILE...
(4) 380/90R46 Tires w/Rims (A64911)
(4) 380/90R46...
Gem 500/200 Gal Herb Tank On Trailer (A64911)
Gem 500/200 Gal...
