Loader John Deere 4100 Hydraulic issues
/ John Deere 4100 Hydraulic issues #1
flahotrodder
lakeland fl
massey GC1710
I am in the process of bringing this tractor back to life after sitting for 4 years. Changed all filters and fluids and it runs and drives great. My problem is the front loader and 3 point will not work. I have done all the usual function checks and cleaned the suction screen on the pump. The pto works fine. I am afraid the internal relief valve may be the problem? Any tips or suggestions would be welcome and appreciated. Thanks, Doug
/ John Deere 4100 Hydraulic issues #2
:welcome: to TBN
Suggest getting some hyd. pressure numbers, and give a shout back.
Were you in this tractors "life" prior to the four years? And if so, how did it function then?
I have been around this tractor since new. It belonged to a friend. It was parked with everything working as it should and the starter went bad. I will purchase some fittings and check pressures. Thanks for the suggestion.
/ John Deere 4100 Hydraulic issues #4
just to eliminate problems - What hydraulic fluid did you use?
Problem solved. When I purchased the tractor the bad starter had been removed. When I installed the new starter I removed the solenoid to gain clearance to install the starter. Apparently the person that removed the old starter removed the suction line for clearance and put the bolts back in finger tight. I discovered this when I found zero pressure on my gauge which led to me diagnosing the pump. Cleaned everything and reinstalled the suction. Everything works as it should now and was not an expensive repair. Thanks to all for their input!
/ John Deere 4100 Hydraulic issues #6
glad you got it figured out.. Welcome..
brian
Case Titan 3530 (A63688)
Case Titan 3530...
2007 GMC C4500 Service Truck (A62679)
2007 GMC C4500...
2015 Peterbilt 337 Galbreath CH8000 Container Handler Truck (A64194)
2015 Peterbilt 337...
2017 FREIGHTLINER CASCADIA 6X4 T/A SLEEPER TRUCK TRACTOR (A59914)
2017 FREIGHTLINER...
Front Tank Bracket (A64127)
Front Tank Bracket...
2018 Freightliner M2 106 AWD Altec AA55 56ft. Insulated Material Handling Bucket Truck (A64194)
2018 Freightliner...
