john deere 1010c
   / john deere 1010c #1
1010crawlerman
liberty,west virginia
john deere 1010c
I have a john deere 1010 crawler I'm have engine issues it's very hard to start but when I get it running it spits and sputters and when u adjust the throttle it dosent work it continues to stay at a low idle.. what could be my problem?
   / john deere 1010c #2
I assume this is a gas model. Most likely fuel issue. When it is running can you pull the linkage on the carb and get it to accelerate. Also clean the plugs. If it's a diesel It is even more likely it is fuel.
   / john deere 1010c #3
   / john deere 1010c
it's gas and I've tried everything replaced plugs, wires, and rebuilt the carb still the same problem
   / john deere 1010c #5
This is going to be a long shot but try adjusting the valves. Older engines suffer from the epa's mandated lack of lead in the gas and the valve seats erode and eventually there's poor compression because of it. Hence poor starting. The throttle I'm not sure. Almost sounds like an linkage or a governor issue. You have fresh fuel in the tank...yes?
   / john deere 1010c #8
Sounds like it could be late timing. Check your timing mark.
2025 K2010 UNUSED Chicken Coop (A50860)
2025 K2010 UNUSED...
2007 Detroit Diesel Series 60 14.0L 6-cylinder Diesel Engine (A48081)
2007 Detroit...
2015 Terex PowerScreen TrakPactor 320 Crusher (A50322)
2015 Terex...
Adams Load Out Conveyor - Stainless Steel Assembly - Baldor Electric Motor (A51039)
Adams Load Out...
Ford Neon Sign (A48082)
Ford Neon Sign...
2008 Honda Pilot SUV (A50860)
2008 Honda Pilot...
