john deere 1010c
   / john deere 1010c #1
1010crawlerman
liberty,west virginia
john deere 1010c
I have a john deere 1010 crawler I'm have engine issues it's very hard to start but when I get it running it spits and sputters and when u adjust the throttle it dosent work it continues to stay at a low idle.. what could be my problem?
   / john deere 1010c #2
I assume this is a gas model. Most likely fuel issue. When it is running can you pull the linkage on the carb and get it to accelerate. Also clean the plugs. If it's a diesel It is even more likely it is fuel.
   / john deere 1010c #3
   / john deere 1010c
it's gas and I've tried everything replaced plugs, wires, and rebuilt the carb still the same problem
   / john deere 1010c #5
This is going to be a long shot but try adjusting the valves. Older engines suffer from the epa's mandated lack of lead in the gas and the valve seats erode and eventually there's poor compression because of it. Hence poor starting. The throttle I'm not sure. Almost sounds like an linkage or a governor issue. You have fresh fuel in the tank...yes?
   / john deere 1010c #8
Sounds like it could be late timing. Check your timing mark.
2017 Ford F-250 4x4 Knapheide Service Truck (A50323)
2017 Ford F-250...
2022 RAM 2500 (A50854)
2004 Tem-Trail T/A 20 ft. Gooseneck Trailer (A50860)
2004 Tem-Trail T/A...
2021 Ver-Mac PCMS-3812 Solar S/A Towable Trailer Message Board (A49461)
2021 Ver-Mac...
John Deere TX 4x2 Utility Gator (A49346)
John Deere TX 4x2...
2019 Ford Explorer AWD SUV (A50324)
2019 Ford Explorer...
