john deere 1010c
   / john deere 1010c #1
1010crawlerman
liberty,west virginia
john deere 1010c
I have a john deere 1010 crawler I'm have engine issues it's very hard to start but when I get it running it spits and sputters and when u adjust the throttle it dosent work it continues to stay at a low idle.. what could be my problem?
   / john deere 1010c #2
I assume this is a gas model. Most likely fuel issue. When it is running can you pull the linkage on the carb and get it to accelerate. Also clean the plugs. If it's a diesel It is even more likely it is fuel.
   / john deere 1010c #3
   / john deere 1010c
it's gas and I've tried everything replaced plugs, wires, and rebuilt the carb still the same problem
   / john deere 1010c #5
This is going to be a long shot but try adjusting the valves. Older engines suffer from the epa's mandated lack of lead in the gas and the valve seats erode and eventually there's poor compression because of it. Hence poor starting. The throttle I'm not sure. Almost sounds like an linkage or a governor issue. You have fresh fuel in the tank...yes?
   / john deere 1010c #8
Sounds like it could be late timing. Check your timing mark.
2014 Forest River Crusader 295RST 32ft. 5th Wheel T/A Travel Trailer (A48082)
2014 Forest River...
2000 MACK RD688 TRI AXLE DUMP  TRUCK (A51222)
2000 MACK RD688...
2010 LACROSSE LUXURY LITE TOURING EDITION TRAVEL TRAILER (A50854)
2010 LACROSSE...
2013 Big Tex 16GP-20 Gooseneck Trailer (A50860)
2013 Big Tex...
2016 Ford Explorer AWD SUV (A48082)
2016 Ford Explorer...
2013 Ford Taurus SEL Sedan (A48082)
2013 Ford Taurus...
